Question about Canon IMAGERUNNER 6570 Copier
How to close printer cover.
I reaplced Ink but i am not able to close printer cover. plz help me.
  • 58 Answers
The ink cartridge is not in all the way remove and retry make sure to get the correct cartridge
Posted on Aug 07, 2009
Why my printer always said cover is open and close ink cover but the ink cover is close and the ink is full?
Hi, Try taking out all cartridges, unplug the printer a few minutes.
re plug , turn on. with ink cover open. then close cover and wait to follow the install prompts, This should reset the printer.
be sure to gently push the cartridges till each one clicks.Close cover.
Please let me know if this helps!
Feb 19, 2015 | Brother MFC 420CN All-In-One InkJet...
Plz solve me problem\r\nmy canon ip1300 printer absorber is problem
This mayclear the ink absorber problem.There is ink absorbers located at both ends ofthe printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 07, 2011 | Canon PIXMA iP1300 Printer
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
Trying to change the ink cartridge out.....but i dont know how can you plz help? it is a mp250
Click on the below link, which will direct you to Canon's site where they store the manuals -
Canon Pixma MP250
If you select the on-screen manual for your operating system (either Windows or Mac OS) it will take you to a downloads screen. About 3/4 of the way down is a tick-box Download - click to select, then a red word Download will appear. Click on this and you will download a file which when run will be the manual for the product which includes instructions on how to change the ink cartridges.
Thx, if this solution helps please rate :)
Feb 08, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to install ink cartridge
Dear Sir,
Plz folow This step to solve your problem,
  1. Step 1 Open the printer cover and prop it up with the support brace located on the right-hand side of the cover. It's similar to the way a car hood is propped open.
  2. Step 2 Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  3. Step 3 Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  4. Step 4 Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  5. Step 5 Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  6. Step 6 A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
Thanks For Your Time,
Apr 24, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error message is causing me fits - won't print
Make sure the top cover is closed as well, Brother has a one year warranty, so it can be repaired at no charge
Jun 30, 2009 | Brother MFC 490cw Color Inkjet...
Change printer ink
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
My MFC-210C always says replace ink.
Try this: Unplug machine from power. Wait 5 min.  Open scanner cover and take the carts out of the holder. Close cover. Plug machine to power. Machine will cycle and demands the carts. Use all NEW carts: Insert carts as demanded and answer question shown on display.
Always print until machine STOPPS printing because of EMPTY cart. Change cart then and machine will print the rest of job!
Plz, never change carts when it says NEAR EMPTY: This will cause a lot of trouble ;-)
Nov 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
26 people viewed this question
old marine
old marine
