Question about Daewoo FR143 Compact Refrigerator
Defrosted fridge now wont cool!!
Hi, i defrosted my fridge freezer following the instructions in the manual. however it wont cool down now. the light comes on and there is sound coming from it so its not totally dead. but it wont cool. is there anything i can do to fix this??
its a daewoo fr-143wh
SOURCE: Fridge not working
Fridge not working,regulator is under repair.can u suggest the services in hyderabad.
Posted on Feb 18, 2008
SOURCE: have Vestfrost Fridge/Freezer was shut
I have the sample problem, Dan in NJ Same exact problem as danilyn....ugh
Posted on Aug 07, 2008
  • 19 Answers
SOURCE: My Daewoo fridge freezer has
Could be stuck on defrost, check behind fridge and look for little white or black box hidden in corners with lots of wires going to it, the box will have a gnarled knob the diameter of a finger, turn clockwise a few clicks to start compressor.
Or it may be iced up and no air flow from inside fan, defrost fridge.
Posted on Nov 13, 2008
  • 400 Answers
SOURCE: some times water flowing from bottom side of the fridge
There should be a drain pan directly below the icebox which needs to be emptied from time to time. Some units have a drainpipe connected at the back, if yours has one, it may have become blocked.
Posted on Mar 13, 2009
SOURCE: GE TFX27PFSM WW Defrost warning
mother board
Posted on Dec 28, 2009
Hi I have a very old KIC fridge freezer the freezer is cold and works well the fridge is not icing up on the back board in the fridge everything going off in the fridge what could be causing this?
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Nov 01, 2011 | Refrigerators
FRIG NOT COOLING - FREEZER IS FINE
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 27, 2011 | Samsung Refrigerators
Evaporator and bottom freezer is freezing up, changed defrost terminator relay defrost element still not getting hot. followed instructions to set up auto defrost element still not hot
Check element out it is probably bad...use and OHM meter to check...
heatman101
Dec 14, 2010 | Refrigerators
Whirlpool Gold fridge not working at all even at maximum coldness adjustment, while freezer is fine. Red light on, indicating bad filter, but frdge not connected to water supply, so changing that wont fix...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 16, 2010 | Refrigerators
Freezer working fine, fridge is 65 degrees and wont cool down
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | Amana Refrigerators
Samsung Side by side Fridge not cooling
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Icing up, not defrosting corretly in freezer. Frig not staying cold enough.
Your refrigerator problem is directly related to your icing up - excess frost / icing up, defrosting problems causes cooling problems.
To rule out other problems shut down your unit and MANUALLy defrost it using a blowdryer, get all that ice buildup melted as well as the evap coils in your freezer - once it is fully defrosted put back the panel and turn on - give it a couple of hours to cool - if it cools properly, it is a defrost problem. Hopefully too, this resets your controlboard.
If problem returns eventually, you have a defrost timer problem and will need to get it checked - it can be any of the defrost components, controlboard, defrost thermostat, etc.
Sep 18, 2009 | Kenmore 53642 / 53644 Side by Side...
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
Daewoo FR143 Compact Refrigerator Logo
62 people viewed this question
Top Daewoo Refrigerators Experts
John Tripp
John Tripp
Jerry Greenberg
Jerry Greenberg
noel
noel
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
