Question about Bemis H12 600 Humidifier
How to put together a Bemis H12-600
Hi I need help on put my humidifier together and i have no manual for this can you help me out
  • 10 Answers
SOURCE: We need a copy of the manual for a Bemis H12-600 humidifier
We found the manual!
Thanks anyway.
Posted on Dec 11, 2008
0 characters
1 Points
Motor just mums and will only start with assistance
The start capacitor is toasted, remove capacitor and take to any appliance parts or electrical store for a replacement. Take pictures of the wiring connectors before disconnecting to avoid confusion later. Have them check capacitor, if capacitor is OK, get an electric motor start up kit, it will give your capacitor more power to start up. Costs less than $20. Take with you the motor info, just in case.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 12, 2010 | Bemis 4D7-800 Humidifier
Fan does not run. What now? Unit has been cleaned, not used since last winter. When I turn on the fan, it does not start - at any setting. Is there a fuse somewhere? Manual which came with humidifier is...
Not sure what solved the problem: Took fan section control box apart, used compressed air to blow out both areas. Noticed that on/off switch did not stay stable, but was able to re attach knob. By wiggling connections and plug-in, it did finally start.
Jan 08, 2010 | Bemis 427 3002 Humidifier
Fill level & digital readout (bemis humidifier)
There is a sticker that comes in the owner's manual that apparently falls out frequently. I was told that the fill level is two inches below the top edge of the reservoir. I am going to mark mine with a Sharpie since stickers have a tendency to fall of when wet.
Jan 05, 2009 | Bemis Whole House Digital Humidifier ED11...
The power light on my Bemis 4D-7800 humidifier flashes.
On my water wheel several parameters must be met. 1. Power on, cord plugged in. 2. Water in tank, the float arm needs to move to indicate water present, the red light on the dash indicates no water. 3. Humidity controll set higher than the room atmosphere humidity, clockwise is higher on mine. 4. The fan speed selecter must be on either high or low, the fan won't run unless one position is selected. I hope this helps
Dec 30, 2008 | Bemis 4D7-800 Humidifier
Water Wheel won't keep turning
This humifier has a black drive wheel and a white idler wheel. On mine, the idler wheel froze up which caused the drive wheel to damage itself trying to turn the drum. First, free up the idler wheel and replace the shaft it rotates on. The idler wheel is still available but you'll have to fabricate the shaft using a machine screw and hollow shaft from your local hardware store. When the idler wheel turns freely, the drive wheel (if still in decent shape) can do its job of turning the drum. If not, you can replace the drive wheel (also still available). I recently put a small rubber band in the groove of the drive wheel and it enabled it to get the necessary grip on the drum.
It's getting harder and harder to keep these wonderful Bemis water Wheel humidifiers alive as the years go by. I wish they still made them because no other humidifier comes close.
Dec 18, 2008 | Bemis 4D7-800 Humidifier
Could you direct me to instructions on disassembling the Bemis 500 humidifier so I can clean it, specifically the fan?
I found your web site to be an essentially useless waste of my time, and was not surprised at all when you offered to sell me something, rather than addressing the problem.
Please stay out of my mailbox; Bemis is on my list of "Do Not Buy" products. Maybe others are as bad, but at least I can give them a try. I already know you guys are are useless sales pitch.
Dec 12, 2008 | Bemis Cool Mist 336 500 Humidifier
Moisture not coming out
i realize this answer is a year old; but, i would guess you didn't let the wick become saturated before running. fill the resevoir with water, then let the humidifier sit idle while the wick is saturating. when it is completely saturated, the refill light will go off. refill the resevoir with additional water, as needed. then you can run the humidifier.
Jan 20, 2008 | Bemis Whole House Digital Humidifier ED11...
Bemis H12 600 Humidifier Logo
Top Bemis Humidifiers Experts
Barrett Palumbo
Barrett Palumbo
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
