Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Westell Wireless Connection & Antenna Problem
I have a Westel 327M Wireless Router. My wireless connection used to work fine through Airport (I have a MacBook), but lately the wireless light doesn't light up on my router. No matter how many times I reset my device, or unplug the cables and plug them back in the box, my wireless connection doesn't work. So, I'm forced to connect to the internet through Ethernet cable right now, but I want my wireless connection back. How can I solve this problem?
Also, I think the antenna for the router might have a problem, but I don't know how to fix it.. All the manuals I've been reading only say to 'align the antenna' in the 'right position' and then tighten it. Which way should the antenna be aligned and how can I tighten it?
4 Suggested Answers
  • 30 Answers
SOURCE: BROKEN ANTENNA
The router comes with an internal and external antenna. Also, it has a detachable one that you can be screw it out. You can check at shopping.com or Epinios.com
Posted on Aug 04, 2008
govinda123
  • 2263 Answers
SOURCE: d-link 615 wireless router having problems
You will need to check the wireless settings of the router. If possible then upgrade the firmware of the router. try changing the wireless channel of the router. Is there any computer connected to the router? If not then connect the computer to the router and open the set up page of the router.
Click here for step by step instructions
Posted on Apr 05, 2010
  • 79 Answers
SOURCE: westell 6100 connected to a wireless router;
You have to make sure that in PS3 you select Automatic Configuration under Network Settings.
In Westell 6100, you have to make sure that there is "DHCP" configured on it. You have to access it via web interface and check under IP configuration or so.
Let me know if you want the detailed process for this.
Posted on Mar 12, 2011
Is there a WIFI Signal Booster out there for a Westell A90-750015-07 Router/Modem?
you don't need a signal booster. Instead what you need is a WIFI signal repeater. This device basically captures your router's signal and repeat it to other devices. Basically place is somewhere between the router and your computer.
There are many out there but here's a cheap one on ebay
http://www.ebay.com/itm/like/122201090687?lpid=82&chn=ps&ul_noapp=true
Apr 12, 2017 | Westell Wirespeed Computers & Internet
I have a RCA Digital Broadband DHG535-2 modem but my Apple Airport Extreme router does not work, any ideas on how to resolve this issue?
Apple uses airport for its wireless connection, how ever the device where you want to connect to should have the wireless feature embeded to it or you should have a wireless router to distribute the wireless signal, if you are using just a modem which doesn't have capability of distributing wireless signals, the Apple airport will surely not work for it requires a modem to connect to. you need to get a router and connect it in your modem so the Apple will work for wireless as well.
Dec 29, 2011 | Computers & Internet
Slow internet connection westell e90-610030-06 dsl modem. was pretty fast 2 weeks ago thanks phil
try to do the ff:
power cycle modem/router
check router security settings
check for wifi barriers
delete previous wireless connections
optimize ie
If your wireless connection is working fine 2 wks ago then you may also try to run system restore
Mar 28, 2010 | Westell Wirespeed LiteLine 6110 Modem
How do I hook up my Westell wireless router to the zhone modem so I can use my laptop. I have to use a dedicated line with a zhone modem to get DSL service. I want to hook up my wireless router Westell...
Connect the Westell wireless to the Zhone as if the Westell is the PC that used to be connected to it. Then connect the PC (through any available port) only to the Westell. That's the WIRED connection. For the wireless to work, after connecting through the WIRED connection, there should be a CD that came with it that will help you configure the wireless.
Feb 18, 2010 | Zhone 6212-I3-200 Router
Connecting 2 pc's to westel modem
No you cant.. But good router I preffer Linksys wrt54G2. Should just be able to plug ethernet from modem to WAN on wrt54g2.
Sep 16, 2009 | Westell Wirespeed LiteLine 6110 Modem
I need to set up my IP provided WiFi router-modem (Westell 327M) for use with my two laptops, such that the router-modem provides me internet access via ethernet cables (not interested in the WiFi aspect...
first check with the ISP if any DNS server settings or proxy settins are required(but i think you can alternatively connect your laptops these may have ben already set on the laptops but just in case)
now if your ISP accepts you to have more than one connection from the same link then you can connect the connect the cable from the modem to the INTERNET/WAN areas and you can connect the ethernet cables in the ports marked 1,2,3,4
here check that if you are only etting the link on the computer connected to port1 and no connection on the others then make a small adjustment disconnect the cable from WAN/Internet port and connect it to the Port1 and the computers to 2,3,4
now that you are saying that u r not interested in the wifi so it is advisable that you go to the home page of the router and from there to the wireless page and disable the wireless broadcast of the router for safety purposes
this can be changed any number of times back and forth
cheers
Jul 14, 2009 | Computers & Internet
Macbook will not connect to wireless connection.
Try to use NetSpot app (it is free) http://www.netspotapp.com/
May 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook 13.3" won't log in to wireless
You need to check your network card software your problem may lay there. I've seen this problem many times in the passed. I will install a wireless network card or software on someones computer and two days later it will not connect everything looks fine. No matter what I do it will not connect. Remove net software for the card or on board wireless reinstall and boom it works fine.
routers may need reset or configured off the internet or the start up cd. I take this a wireless router hooked to internet gateway. don't know not enough information you may need to tell me a little more. first try install of net-card software then set you working router to unsecure no pass word need see if you connect then change it to you wpa password protected.
Mar 20, 2009 | Apple aluminum 13-inch MacBook laptop-...
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Cannot connect using westel 327 from verizion --lights blinking(dsl)
If they are charging you for the use of the westel, just tell them you don't need it. I would keep using your other modem that works.
Jan 28, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
118 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
