Question about HP OfficeJet D135 All-In-One InkJet Printer
HP Officejet d135
If I copy or scan a solid white sheet of paper, the entire sheet comes out yellow/gold color.  Same way when I copy or scan images, all of the white colored areas in the image is a yellow/gold color.  It shows to have
50%- 60% ink in both cartridges.
Thanks,
Don
Take out the printer heads and clean.
Posted on Nov 28, 2007
Single narrow black vertical line about 1 3/4 inches from right side of copy. Line runs the entire length of the copy. Happens only during copying color or black and white.
The line issue is caused by something on the image sensor. To get to it and clean it just pull the front up where you put the paper into it to scan. Inside you will find a glass strip, this is the image sensor. Use a paper towel dampened with window cleaner and gently scrubbing the glass strip, After cleaning the strip let it dry for a minute or teo before you close the cover and try a scan. It should be clear and should copy great again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Jun 18, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Minolta cf3102 printing yellow where white should be
There could be 2 reason for this, first Imaging Unit or Laser Unit, the easiest way to try changing the Yellow Imaging unit, If the problem is not solved, Swap the laser unit yellow one with another laser unit,check if the problem is shifted to the color to which laser is changed
May 07, 2009 | Konica Minolta Office Equipment & Supplies
I620 scanner
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Nov 07, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
Infoprint 1332
in valid cartridge refill
Oct 21, 2008 | IBM Infoprint 1332 Laser Printer
Copies from multiple trays
No, you will have to put your paper like you want( one sheet white and one sheet yellow and so on ) and put it in the same tray !
Mar 25, 2008 | Lanier 1205 Copier
HP OfficeJet D135 All-In-One InkJet Printer Logo
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
