Question about GE Profile Harmony DPGT750EC Electric Dryer
Heat in the dryer but blower not working
Amana NED7200TW dryer. Has heat, tumbles, clothes don't dry. Vents have been gone through and cleaned. This happens in the sensor dry and time dry modes. Any thoughts? Thanks!
Just a question. Does your blower work. If your blower does not work it won't dry. Check blower belt. Mine broke and had no air blowing. Just a thought.
Oct 21, 2016 | Amana NED7200TW Electric Dryer
GE Profile Harmony Gas Dryer not heating/drying clothes.
let me ask you this does the ignitor glow orange but no flame when you have no heat?usually on a gas dryer if at first you have heat and then after 10 to 30 minutes no heat it's usually the gas coils located on top of the gas valve,common problem,after the coils cool down they will work again,that dryer is kind of complicated to work on seeing how it does have two motors in it but you should be able to get at the gas coils,if you send the model number i can look it up for you.but it sounds like you have bad gas coils,the only way to tell is run the dryer,when the heat stops working look at the ignitor,if it glows orange and the flame doesn't ignite you have bad gas coils.
Feb 14, 2014 | GE Profile Harmony DPGT750GC Gas Dryer
Heat stays on while blower is off and burning fuze
If you mean that the dryer timer is at "OFF' and the heater coil continues to heat, then the timer contacts are "welded" together. Check/replace the timer.
If you mean the blower is not running during a drying cycle, the the various heat-sensors, including the thermal-fuse are doing their jobs. Find out why the blower is not working: Bad motor, blocked 4" duct, etc.
Oct 24, 2013 | Amana NED4600YQ Electric Dryer
I have a ge harmony gas dryer and the blower isn't work can this cause a no heat issue
Yes. The blower draws the air from the heat source thru the tub and out the blower exhaust. This link should help with the Blower wheel assembly they also have diagrams or illustrations of your specific model
Sep 23, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Kenmore dryer, not heating and blower not working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 09, 2010 | Dryers
if nothing is working you can unplug remove the back and check the main fuse located on the blower box to the right,also check the door switch if it does not work nothing else will
Mar 16, 2010 | Kenmore Dryers
Dryer is not heating enough to dry clothing. The problem started with the electric braker box switch triped i had to replace it, dryer would turn on but no blower, I took a look at it and found some...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
87gh
Dec 09, 2009 | Estate TGDS740JQ Gas Dryer
Heat Element is working and drum spins, but no air is blowing?
First make sure that the dryer is vented properly, then check the blower wheel. A common problem is for the center of the blower wheel to get rounded out through wear and tear, allowing the blower wheel to spin on the shaft, thus not spinning at the same speed as the motor. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 07, 2009 | Maytag MDE308DAYW Electric Dryer
The blower and heat are not working my ge harmony electric dryer
If blower isnt working you wont feel any or very little heat in the drum
Aug 19, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge harmony won't heat up and blower does not work
Found Manual here:http://www.affordableappliance.com/Download%20Folder/GE_Harmony_Dryer.pdf
GOOD LUCK!
Mar 11, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
420 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
