Question about Brother XL-3500
My four-year-old XL3500 seems to have a tension problem. It was sewing fine until after I refilled the bobbin, changed thread twice, and did some zigzag stitching. Now the top stitch is not correct; it pulls out. The bottom stitch looks right. I cannot find how to adjust the tension.
  • 37 Answers
According to the diagram in the manual, the upper thread tension is set by the wheel/knob on top and just to the right of the thread take up lever and thread guide. If you don't have a manual, go to www.brother-usa.com they have a downloadable manual for your machine.
Posted on Jun 05, 2009
Top thread is hanging up somewhere under feed dogs. With and without bobbin in place. Any suggestions.
1. Make sure to adjust the bobbin tension. Also, make sure the bobbin is correct for the machine. If it is too tall it will surely have problems. (see attachment for bobbin tension adjustment)
2 Always thread your machine with the pressure foot up. As you thread give gentle tugs to check for hang ups. This has to be corrected.
3. Adjust the top tension to four to begin with. Final tension adjustment can be made when you give a trial sew.
*Always oil race w/one drop of oil before the bobbin case is placed back. This is done only about every 10000 stitches.
Aug 14, 2015 | Brother XR 7700 Computerized Sewing...
My Singer Futura II, model 920 won't sew. The top thread is threaded correctly, new needle, tension set correctly and the bobbin won't wind with thread. I have had this machine since the early 1970
IF IT WON'T SEW AND THE BOBBIN WON'T TURN FREELY THEN THE SIZE OF THE BOBBIN IS WRONG. MAKE SURE IT IS THE RIGHT HEIGHT AND WIDTH. THE RIGHT TENSION OF THE BOBBIN HAS TO BE RIGHT OR IT WON'T SEW RIGHT EITHER. IF THE BOBBIN DOESN'T WIND WHEN YOU ATTEMPTING TO REFILL IT THEN YOU HAVE A BOBBIN THAT IS THE WRONG HEIGHT.
Sep 07, 2014 | Singer Sewing Machines
Top zigzag is fine, bottom is loose
sounds as if it has insufficient top tension, clean between discs then re thread with presser foot down
Feb 17, 2014 | Singer 4423 Sewing Machine
Bobbin thread not sewing tight
try adjusting the top thread tension one number or letter higher
sewing on a scrap piece of fabric till the stitch looks normal.
Jan 17, 2013 | New Home 2014LE Mechanical Sewing Machine
I get major tangles with lower thread and cannot sew. I've cleaned the shuttle and machine, changed needle, thread, bobbin and wonder if the shuttle is damaged....How could I tell? If so, is a...
It could be a mechanical problem but before you do more first check your UPPER tension. If the upper thread tension is too loose and the bobbin tension is tight you can get looping on the underside of the stitch. So pull on the upper thread and feel if there's tension there. You can try to increase the upper tension and see if that helps.
Jun 19, 2011 | Brother CS-80
Bobbine keeps getting knotted up, I have replaced it with a new bobbin and it keeps happening.
Hi my name is John. Welcome to FixYa. If the bobbin is knotting up, you need to loosen the tension on the bobbin and tighten up a little on the thread, you kinda have to play around with it a little to get the feel of it. Say may less than a half a turn, until you get it to where you want it. Then there will be a question about the thread breaking, sometimes it will be old outdated four year old thread. Thanks for choosing FixYa...John
Dec 08, 2010 | Janome Sewing Machines
My machine is about 20 years old but in very good condition, i have never had trouble with tension untill about a month ago, but now i cant seem to rectify it i have broken a few needles trying to sort it,...
It sounds to me like something may have been accidently changed. Double check bobbin is clean and in correct position. Also see if there is a thread caught in one of the tension guides, by pulling a thread carefully through the machine towards the needle.
Rather than breaking needles, test the tension by putting foot down and pulling on thread by hand , if its too easy to pull through something is causing the tension to be too loose
Sep 14, 2010 | Riccar R1570 Mechanical Sewing Machine
Kenmore Sewing Machine Drop-in Bobbin Tension Adjusting Problems
looped stitches are usually caused by improper tension. when the loop is on the upper side, it may be corrected by loosening the top tension or by tightening the lower tension (turn the tension screws on the bobbin a hair at a time)
since using the machine only a few times it is best to clean the machine from dust (can use a can of air) blow air into the bobbin area and between the tension disks and under the throat plate.
make sure the machine is threaded correctly and bobbin is evenly threaded
Aug 26, 2009 | Kenmore Sewing Machines
Thread caught up around bobbin!
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Nov 12, 2007 | Kenmore 15516 Mechanical Sewing Machine
Brother XL-3500 Logo
289 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
