Question about Craftsman Garden
Tried to install a new drive belt on my Sears
Tried to install a new drive belt on my. Went on ok. Now lots of smoke. Belt strikes one of the post which keeps the belt on the pully. Local Sears repair center wants me to ''bring it in''. I only need to diagram. PLEASE HELP. Wife cannot mow till I get it on! Thanks RMD 32615
  • 61 Answers
If its the one on engine you have to take
bolt out of the center of the pulley and let
the pulley down just enough to get the belt by
it reinstall the bolt and your done.
Posted on Sep 06, 2009
How do I install fan and alternator belt?
question 3 , and double posted....
and still no hint as the the JOB.
what are you doing and why, so we are on same page?
wow,,, you do make this so hard.
if the questions is new belt time"only"?(yes? do i guess good?)
then i posted last post all 11 steps from the real fsm ON REMOVAL. so, now I add page 2.
So now you want ,INSTALL too?
the below only works if you did page 1 correctly
ok here. 11 more steps, totaling 22
Install the drive belt to the crankshaft pulley, the tensioner and the generator.
Rotate the drive belt tensioner clockwise.
Install the drive belt to the idler pulley (1).
NOTE
Important: Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
Slowly release the drive belt tensioner.
Raise the vehicle.
Install the right side engine mount bracket. Refer to Engine Mount Bracket Replacement - Right Side .
Install the engine splash shield. Refer to Engine Splash Shield Replacement - Right Side .
Lower the vehicle.
Install the engine mount strut bracket. Refer to Engine Mount Strut Bracket Replacement - Right Side .
Remove the engine support fixture. Refer to Engine Support Fixture .
Install the the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
Jan 08, 2016 | 2005 Suzuki XL-7
I just installed a power Steering pump and pulley. On my 1994 Chevrolet blazer . The belt is squeaking and smoking what's wrong?
Hi,for the belt to be squeaking and smoking the belt must be slipping,check all pullys spine freely if ok then check tension and if still smoking and sqeaking relace belt.
Nov 26, 2015 | Chevrolet Cars & Trucks
Tractor moves 5 feet then stops belt starts to smoke
There is something in a wad! You cranked it up to warm up. You drove it to the crime scene. You first engaged the blade which was OK?
Then released clutch to drive which, smokes the belt.
Most interesting and perhaps you tried to cut some super thick grass at high driving speed with a low/dull blade and the belt just can't tolerate that combination.
Sep 10, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Lt 1000 new deck belt is smoking, is there a break-in period for new belts?
First, you need to check to make sure you have the belt on correctly. There needs to be a tensioner holding the belt in proper tension. I have had a few deck issues where a bearing is worn out and it could be smoking when the grease gets hot. See if you can get a diagram for the belt position and check your bearings and idlers. Also make sure it is cleaned out so that you don't have a lot of grass in there that could be burning and smoking.Good luck.
Jun 17, 2012 | Craftsman Replacement Belt for 42" Deck
I have a 22.5 craftmans riding lawn motor Model number 917250560, serial number 051595C 002994. What size is the drive belt.
My name is Dane and I am going to help you solve your problem. Your Hydro drive belt Part number is sears part number 140218 which is a 1/2 x 84.5" belt. Well, I hope I've helped. If you found this reply helpful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Dec 06, 2010 | Craftsman Garden
Husqvarna CT151 Smoking
the belt is smoking because a pulley isnt spinning like its supposed to. its gonna break the new belt if you don't remedy the problem. try taking the belt Back off. then see if you can spin the pulleys by hand with no belt .
Jul 31, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Diagram with replacement belt doesn't seem to match old manual
I haven't worked on a belt drive but here is the Sears parts site for your washer with diagrams of the console, drive system etc. You may get a better idea of how to replace the belt from these.
Here also is the Whirlpool / Amana installation and maintenance document for Amana belt drive washers. It may look similar to yours.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56310258b0952a4e8525729c0056d75b/$FILE/Amana_Searcy_TL_Washer.pdf
The other thing I'd check is Whirlpools list of documentation for their laundry products. Check some of the washers that they make for one that looks like yours and you should get a better idea.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1&Count=30&Expand=6#6
Oct 08, 2009 | Kenmore Washing Machines
Two days after I had a new starter installed in my 02 durango, the A/C quit and there was a loud "blower" noise coming from the engine compartment. I lifted the hood and the noise was from the serpentine...
It sounds like the a/c compressor bearnig has gone bad and seized, but check the other pully bearing like the idler and tension bearing just to eleiminate the other bearing for failure. Good luck and keep me posted. If it is the compressor bearing that went bad, you can remove the a/c compressor and buy a serpintine belt that is smaller for your dodge without the a/c compressor. Make sure you know the routing of the belt without the compressor. Good luck and keep me posted.
Jun 27, 2009 | 2002 Dodge Durango
When washing a load, it made a wierd noise then smoke came out.
Unplug your unit then tilt it back. Check your belt to be sure it didnt pop and get hung up in the motor assembly. If belt seems ok, look at the main drive pully, see if it turns freely. If not, the brake assembly or transmission may have went bad, and you will need special tools to remove it. Do not try to take apart brake assembly, it will pop off and injure (people have actually been seriously hurt, and have heard of a death or two) you. Let me know what you find out, and will go from there. Thanks!!!!!
Feb 09, 2008 | Maytag Performa PAV2200
Garden Logo
74 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
