Question about Panasonic Audio Players & Recorders
I used wrong power pack and its completely dead. panasonic rf-d1. is there a reset anywhere .?
  • jackire Jun 04, 2009
    i tried the 3 button trick and was unsuccessful.
    Genius:
  • 1,689 Answers
Hi jackire,
the unit has a breaker on its power supply, using an incorrect powerpack will break the fuse i the unit leaving it dead but protected from the surge that came in.
if this is still in warranty have it brought to the dealer to have the circuit breaker replaced. or a local repair shop will do it for you for more than 75 dollars.
hope this helps.
regards,
voodoo
Posted on Jun 04, 2009
    President:
  • 1,197 Answers
With radio unplugged from power hold in all three buttons in a row on front panel ,while still holding in buttons plug in swithed on power plug leave for several seconds then remove plug ,then plug in and switch on as normall .it worked for me
good luck have a nice day
Panasonic Viera TH-50PX80A. After lighting strike, inputs do not work.
The set MAY have a hard reset but you would have to call Panasonic to find out.
What happens with lightening strikes is RF gets into the set in two ways--via the power cord (usually a dead set is the result) and via the coax or cable fitting.
It sounds like it was the latter--it may have confused the microprocessor in the set(input issues) so unplugging set and or a box if used (receiver unit also!) may or may not help.
Surge protectors rarely operate quickly enough to stop this and even if the cable feed is protected stray RF can get past that also.
try my suggestions and then call Panasonic.
May 17, 2012 | Televison & Video
My wife plugged a wrong charge (16V instead of 12V) to the Panasonic LS82. It wasn't turned on. The charging light was flashing, now it's dead. Is the battery pack dead or the whole DVD player? Anyway to...
Ur wife overload,the power board,and also kill the litium battery.This DVD player exspensive?Not,not worth repairing,must take to shop,probally must order the power board for replacement,to repair for u.
Apr 06, 2010 | Panasonic DVD-LS82
It has completely gone dead, there is power coming to the unit. I believe I accidently turned the unit on to heat yesterday with nothing inside instead of turning on the timer thereby allowing the unit to...
You already know it can be a costly mistake. Had it happen in my own home!!!!
Several things can be wrong:
1. The Fuse inside the unit
2. The High Voltage Capacitor
3. The Power Diode
4. (bad news) The Magnetron.
There is an RF window that can be bad also as when a microwave is run with no load it can be burned. It is supposed to help protect the Magnetron from reverse flow RF and help disperse the RF inside the unit.
The next question is: "Are you going to talke this by yourself or have it repaired?" We can you advise on what to do but there are some hazards that you need to be aware of if your going top give it a go..... Just reply here. Thanks.
Jan 24, 2010 | Jenn-Air JMV8208A Microwave Oven
Panasonic RF-B65 short wave radio won't tune to frequency when turned on, just flashes 'E' and turns off automatically. Any suggestions ?
RF-B65 has a known issue with the power connector on side. It gets resistive from not being used. If you apply 6 vdc and it works, its most likely the batteries or the power connector. If both produce a "E" its PLL doesnt lock. Power plug most likely issue. Another issue is the tuning knob. It skips or jumps irratically. The up/down frequency changes are by a cube 1/2 inch square contactor. Its not optical. Just simple mechanical contactor. Remove the small cube from chassis and spray liquid gold. It will clean wire contactor and lubricate internals. You cannot buy the cube. Cleaning it always works for me. RF-B65 radio is a sure winner. Small, reliable and very sensitive. Has SSB also. eter
Sep 06, 2009 | Panasonic Audio Players & Recorders
Phone is completely dead and i need to reset it
You may need to replace the rechargeable battery in it. Radio Shack used to carry some of these packs. They are usually 3 cell NiCADS.
Jul 28, 2009 | Lands Phones
No 1384 firewire driver for Panasonic PV-GS300 camcorder
I found the recipe. To get my DV Camcorder to work using 1384 (Firewire) on my computer I did:
1. Get a good cable. If you paid less than $20 for it, you got the wrong one.
2. Ensure that the 1384 (firewire) port is enabled on your computer. Go into the BIOS setup and check to be sure. Mine was OFF!
3. If you get an error with Windows XP not being able to find your hardware, you need to get all the drivers. There are four or five of them along with a configuration file. Miss any one and you are dead. My solution was to reinstall Windows Service Pack 3. This took a long time, but fixed the driver problems.
Feb 17, 2009 | Panasonic PV-GS500 Camcorder
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
Panasonic DAB RF-D1 Radio..
The internal 5v battery is flat
Aug 31, 2008 | Audio Players & Recorders
Panasonic RF-D1 code f76 pdet
Seems to be a problem with a Transistor BD244c PNP. Old problem of 3years plus wich means are the goods fit for purpose as defined by The Sale of Goods Act/ If not even if they are out of warranty you should get a replacement or your money back
Apr 12, 2008 | Audio Players & Recorders
73 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
