Question about BenQ FP71G+ 17" LCD Monitor
During use playing games the screen suddenly went black; i operate two monitors simultaneously and the cable works fine on the other monitor and both graphics cards are working, any ideas on how to fix it?
    Scholar:
  • 52 Answers
Hi, if you loose video on both monitors, that means there is a problem with the video cards. I guess you already tried to update the video drivers to the latest ones, so the only thing remaining is maybe an hardware problem with the video card. Try to play your game at a lower screen resolution and see what happens. Also, if you have a flatscreen monitor, try to lower the refresh rate at the default 65Hz or 70Hz. If after 30 min or so you still loose your image, make sure the monitors are still powered (usually the green light will turn orange awaiting a singal to open and turn green then) Some video cards got some issues with heat after a certain amount of time. Something about GNU but i'm not 100% positive. Anyway, in that case, you may have to replace your video card, god of waranty please be with us! good luck
Posted on Jun 04, 2009
My Benq monitor was working, then it suddenly went black and said Hdmi no signal. After a few hours, it started again fine, but when I tried to play a game, after a minute or so it went black and star
Check the signal cable connected in between monitor and system for firmness. Re-seat at both end once and check. If it does not help you, contact any service technician. Gopakumar Gopalan Google
May 11, 2014 | BenQ Computers & Internet
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
Acer X233H monitor whilst in use suddenly went black
sounds like the video card went out or the cable shorted can you try that monitor on a friends computer?
Nov 30, 2009 | Office Equipment & Supplies
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Oct 28, 2008 | Computers & Internet
Monitor out of range when a game is booted up
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Jul 29, 2008 | Compaq MV 540 15" CRT Monitor
Samsung SyncMaster 17" LCD Blacks out
If you have a second monitor, you could use your computer until the monitor goes black... then plug in a replacement monitor. My guess is that one will display black too...
My gut feeling is that your VGA card is on the fritz... I'm not convinced it's your monitor. Do you have a replacement VGA card you can try? I'll bet that'll take care of the problem.
Apr 22, 2008 | Samsung SyncMaster 17" LCD Monitor
BenQ FP71G+ 17" LCD Monitor Logo
97 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
