Question about Sewing Machines
I have a Viking 6270 sewing machine that won't do a zigzag stitch
I have a Viking 6270 sewing machine. A few years ago I brought it in to be reconditioned. I've only used the machine a few times since then. I recently have started to make some of my clothing. The machine will do a straight stitch, but not a zigzag. The needle arm doesn't move side to side. What are possible solutions?
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
  • 1027 Answers
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
SOURCE: Will not zigzag
Have the hook timing checked on your machine.
Posted on Oct 10, 2008
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
Recently my sewing group was given Husvarna Viking Emerald 116. Stitch width is off.
Be sure and use the correct sewing foot...the machine is probably reading the foot and won't let you make adjustments. Also make sure the needle plate is the correct one.
Jun 01, 2016 | Husqvarna Viking Emerald 116 Sewing...
I have dv9117, whenever I use the special stitches or even just the zigzag, it just keep doing straight stitch. Did all the cleaning, re-threading, taking out the bobbin and rewound bobbin thread. Nothing...
aside from cleaning, with a thread bunching problem it's always good to change the needle and make sure the top thread has not come off the thread take up lever and make sure the bobbin is turned the correct way in the bobbin case.
as for the zig zag stitches, it sounds like a gear or cam could be damaged or worn.
if someone brought me a sewing machine with the same problem, the first thing I would check for is a damaged or worn gear..
Oct 01, 2013 | Singer Sewing Machines
Sewing machine won't take a single stitch
WOw Paying attention would have been best...Thread machine properly of course, insert bobbin spinning in the correct directions
a simple top stitch sounds fine. Go On You Tube and look for your machine, and a descent video of someone using it.
Cheers,
Embroidery Services
San Diego, CA
Sep 09, 2017 | Sewing Machines
I have a Viking 6370 sewing machine. I can not get the stitch selector to turn to select a new stitch. Actually the knob will turn but the outer dial doesnot turn and the stitch does not change. It sews...
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Jul 12, 2011 | Husqvarna Viking 1
Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Jan 25, 2010 | Husqvarna Sewing Machines
Viking is skipping some stitches when it is on zigzag
These are great machines but after 25 years there are probably a lot of problems that need to be fixed. It could be as easy as buffing or replacing your needle plate. If you take it in for service (and can actually find someone who is good with this machine) you will probably pay $200 to $400 to get it back to 'factory' state.
Jan 29, 2009 | Husqvarna Viking 1
Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Jan 13, 2009 | Brother LS-1217 Mechanical Sewing Machine
Singer 5050 won't zigzag stitch
I have this same issue with that same machine. Did you ever figure out what was wrong with it??
May 08, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
354 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
