Question about Casio EXILIM EX-Z1000 Digital Camera
CAMERA WILL NOT TURN ON
Everytime I turn on the camera, the lens comes out but after a second the lens retracts and the green light below the shutter button flashes. Can you help?
  • 5 more comments
  • steenp Jan 13, 2008
    Sorry to tell you that we have the same problem - looking forward to get help :-)
  • GrmpaJ Mar 02, 2008
    Camera worked fine until I tried to turn it on after use tonight . . . now the lens comes out and the green light flashes and it turns itself off . . .
  • sarah786 Aug 11, 2008
    I have the exact same problem, down to every detail in the description
  • caussl Nov 19, 2008
    i have the same problem it happened after i decided to take pictures outside during a sandstorm leading me to the conclusion that there could be some thing in the lense
  • Anonymous Dec 09, 2008
    I HAVE THE SAME PROBLEM... I LOVE THIS CAMERA I JUST WANT IT TO WORK!
  • Jeaniebottle Feb 04, 2009
    I have the exact same problem too, although I tried pressing the shutter button and the on/off button and it doesnt do anything other then extend and go half way back in again. I can't find anywhere on the net how to reset it, theres got to be a way?
    Only thing I've found is that if you press the menu button and on/off it says ver 1.01 on the screen!
  • redgreen0289 May 16, 2009
    I have the same problem, think that it's related to formatting a 4GB SD card with the OS only supports 2GB... camera has never acted the same since... I've been putting up with this for 2 years, and am ready to send the unit back to casio, and if it's not resolved switch brands. Too many people are having this same problem....
  • 130 Answers
I had the same problem when i went to casio they told me it was the battery so ibought a battery when it did not fix it i got my other digital camera switched memory cards now it works fine so i guess i'll be buying a new card on the bright side the memory card worked fine in the other camera and now i have an extra battery which i got from sourcing map for $8.99 my only complaint was that it took almost a month to get here but was still $30 cheaper than wal-mart
Posted on Feb 09, 2009
  • 3 Answers
I had exactly the same problem I seem to have solved it by holding down the shutter button and then pressing the on/off button. It powered up and the lens stayed out. It was not auto focusing, so I placed it into manual focus and ran it back and forth in manual focus mode. (The circular button on the back adjusts manual focus by pressing it to the right or left) I suspect it's part of the start up self test that checks to see if the auto focus system is working, if it fails it shuts off. I think I stumbled onto a override of sorts by the button combination. Running the manual focus seemed to help. I do have a small black area in the upper right of the screen that gets no light - a dark spot. I store the camera in my pocket, I wonder if some pocket fuzz got into the camera somehow...
Posted on Aug 26, 2008
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Shutter stays open
Lens is jammed , needs to stripped and reset.
Apr 21, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Leica C1 -- Unusable, electronics haywired
hi,
your camera needs cleaning of lens and lens shutter; because some time dust particles gose inside and effect the alignment of lens and cause camera not working.
please give me good rating if the solution works
Thanks for using FixYa.
Jan 05, 2009 | Leica C1 35mm Point and Shoot Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Kodak Z700
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Jun 08, 2008 | Kodak EasyShare Z700 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Casio EXILIM EX-Z1000 Digital Camera Logo
289 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
