Question about Toshiba Satellite A60 Notebook
I left my toshiba laptop with no batery i totally did not see the batery was low so the laptop turned off completly i connected the charger and let it charge for a while the i turned it on an it looks like its going to turn on but it takes me to a screen were it gives my 4 options to turn it back on and i highlite the options to turn back on windows on safe mode but it takes me back to the same screen . can you help me fix my lap top
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Go into safe mode if possible and choose the last known date that the laptop was working properly. Let it restore and then see if you can get back into windows.
Completely dead laptop.
sometimes you just need to remove the battery then power-up the unit using its charger.
Jul 05, 2013 | Toshiba satellite c660
there must be the problem with laptops motherboard
most probably you should call customer care and said them to change the motherboard or if laptop is not under warrenty you can go to some local shop and show it to him (it will cost you less)
I have a toshiba sattelite l3oo and i have a problem with my charger. when ever i plug my charger the laptop will reboot(when starting. i can't start the computer when my charger is on. and when i'm using...
I had same problem with my Sattelite L300. Motherboard has a defect in one Proadlizer film capacitor exactly on the back of CPU, the original ref. is nec-tokin 0E907 (900uF/2.5V) or similar code. I've replaced it by 4 tantalum capacitores of 470uF/2.5V each and 2 capacitores of 220uF/2.5V, all in paralell mode in same old place of nec-tokin component.
Vote for me... :)3_10_2012_6_45_55_pm.jpg
Apr 12, 2011 | Toshiba SatteliteĀ® A105-S2051 PC Notebook
Problem: A100 flashing Amber light but won't turn
Check your charger. It seems to indicate low batery and the charger may not work or the power socket has a faulty connection. Check for phisical damage in the power socket of you laptop.
Try to twist it or even push it in a bit while trying to switch on. Try also to remove the baterry and use the charger power supply only.
If nothing happens its very likely to be the charger.
Jul 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
When i plug in my toshibba satellite a205, the plug light turns on, but the batery charge lights flashes just once, then goes off. my battery says 2%, not charging. is it a battery or combination laptop...
True turning it on while pluged in but without the battery in. If it works its your battery if not it is you charger or laptop, my bet is on the charger they have a tendancy to go out.
Feb 14, 2010 | Toshiba Satellite A205-S4777 Notebook
Toshiba Satellite A135-S4527 WILL NOT POWER UP. WHAT COULD CAUSE THIS PROBLEM?
check the charger if working or not, remove the batery then turn on your laptop.. if the same problem check the dc jack connector... or chips
Jul 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Laptop is not working
remove the battery fact the connect the charger direct, then turn on you laptop if the same problem.. check the baord where comes out the sond,, check the ram ro boar
Jun 26, 2009 | Computers & Internet
Cannot charge battery
i would replace the charger 1st seeing as its the cheapest thing to do. if that doesnt solve the problem. return the charger to where ever you got it from and purchase a new battery.
May 18, 2009 | Casio Cameras
BATTERY NOT CHARGING
sound like you need a new mp3....might not be the charger
Feb 20, 2008 | Audio Players & Recorders
Toshiba Satellite A60 Notebook Logo
93 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
