Question about Brother IntelliFAX 4100 Laser Fax
When I get or receive faxes, the right side is blurred.
The right side of the received fax cannot be read. I tried copying something and it's the same. The left side prints good.
  • 48 Answers
If your getting blurred copies you may have moisture on your drum. Try cleaning it with alcohol(only) . If the problem persist replace drum.
Posted on Jun 06, 2009
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Black strip in documents when I send a fax
If you lift up the top, like you are clearing a jammed original, you should see a piece of glass across the machine. Look for something on the glass, usually white-out, and clean it. Test by making a copy. If copy is ok, then you fixed the problem.
Jul 12, 2010 | Brother IntelliFAX 4100 Laser Fax
Several recepients cant read my fax, very feint. Is it a fault with my fax?
Try making a copy on your machine and see what the copy looks like.
What are you sending,??? if its a second carbon copy of something...remember what you see is what you get...if the original is poor quality the receiver will get poor quality. You can darken the image slightly...refer to your operators manual.
Jun 16, 2010 | Samsung SF-560 Plain Paper Laser Fax
Some lines are missing when receiving faxes
Horizontal or vertical? Or do you mean lines of text?
Did you try to copy a document? If the copy is fine, then the fault is on the sending side, or there are severe transmission errors.
If the copy exhibits the same faults as the received faxes, then something is wrong with the printing part of your fax, and solving the problem will depend on the printing technology used (inkjet - clogged heads, need cleaning, or empty ink, needs replacing etc.)
Feb 10, 2010 | Office Equipment & Supplies
The receiver states that our faxes that we send are unreadable down the right side of the paper--white or dark streak. The faxes we receive are ok
The glass scanner window (narrow strip of glass) needs cleaning. One "spot" of dirt will appear as a streak on the receiving end.
If you "copy" a document you can check the streak and see how effective your cleaning is.
Sep 28, 2009 | Brother IntelliFax-2820 Laser Fax
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Receivers complain that the fax is light/unreadable
More than likely (since the problem is with sending and copying only) the mirrors inside the fax machine need cleaning. However, depending on what type of fax machine this is, this could be a pretty involved job. If you are pretty comfortable with taking covers off, you might try it, but if its a pretty expensive fax machine, I would call a professional.
hope this helps!!!
chad
Oct 08, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Fax problem
How is the copy when you try to just make a copy of something? If it copies good, then it might be the senders machine.
If when you make a copy, and the copy is blurred, then it is probably your ribbon/ink cartridge.
If it is the cartridge, just replace the cartridge, and you should be good to go.
Hope this solves your problem.
Good luck.
Mac =)
Feb 09, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Intellifax 4100 won't receive faxes
Make sure the green light that says "FAX" is lit by pressing the "Mode" button in the upper right corner of the unit
Feb 07, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
99 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
