Question about Tools & Hardware - Others
Porter Cable 2 inch brad nailer piston does not return
My Porter Cable 18 gauge 3/4-2 inch brad nailer, model BN200, gradually stopped working because the piston no longer returns all the way to the top, thus blocking the next nail from entering the firing chamber. Lubricating and replacing all o-rings did not help. No obvious signs of wear, dirt, or damage. Any suggestions? Thanks.
    New Friend:
  • 131 Answers
Sounds like the cylinder check seal. That`s the o`ring on the outside of the cylinder sleeve. With little holes in the groove. You have to remove cylinder sleeve to get to it.
Thanks,
Jeff
Posted on Jun 24, 2009
I have a Porter Cable NS100 and a BN200 and both are leaking air from what appears to be the exhaust at the very top when I plug into air hose.....will not hold pressure.
have you oiled this tool .and if so are you sure this tool uses oil.because some nailers do not use oil and if you oil it they will most likely stop working .if this is the case you will need to take it apart and clean it with a mild cleaner .we use a water base cleaner to keep it from damaging the orings. if this doesnot fix it you will probbly need to put a Oring kit in it.you shoul be able to get this a ereplacement.com .i hope this helps you out.
Sep 27, 2014 | Porter Cable-Cable BN200B 5/8-inch to...
We don't know how to put in new staples. We r fixing a chair
If your brad nailer is a BN200; I don't believe it will accommodate staples.
Feb 14, 2011 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
The driver doesn't return after firing. it is a porter cable brad nailer BN200
This is pretty common with brad nailers
Remove the brads from your gun - disconnect from the air supply
On the front of your gun is a latch - open it
Check the sliding surface for build up of dirt or small pieces of metal from the brads.
Once clean polish the surface with a fine steel wool or a small brass brush
Reassemble with a drop of machine oil on the sliding surface
Oil your gun as you normally would
Using a piece of soft wood dry fire the gun 10 or so times to ensure that the dents it is making in the wood are all pretty even
Reload and nail something
Mar 08, 2010 | Porter Cable-Cable BN200B 5/8-inch to...
Porter cable bn200 nailer
Get a gasket kit---sounds like top seal around barrel
Feb 21, 2010 | Porter Cable-Cable BN200B 5/8-inch to...
BN200A porter cable brad nailer. have tried
check for a broken driver blade, also make sure of the proper nail guage for the tool. Let me know if this is not the case and I will find you a breakdown for the tool for further inspection.
Nov 06, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Driver will not return to rest position,
The plunger or anvil has damage, or your return spring in the chamber is broken. This could also be caused by mechanical issue in the anvil track.
Oct 22, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Porter Cable 18 ga Brad nailer - BN200 Will not reload
Strip and clean the whole diaphragm and spring arrangement. Also check whether a bad nail hasn't damaged the piston guide and caused it to jam when on return stroke.
Jun 13, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Will not pull piston back after shooting a nail
first thing i would do is to make sure this gun needs oil .most of your newer guns don't take oil.and if this is true with your gun you will need to rinse all of it out, hear is a place you can get a schematic. http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/portercable/BN200
Mar 26, 2009 | Porter Cable-Cable BN200B 5/8-inch to...
Tools & Hardware - Others Logo
371 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
