Question about Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis doesnt run
Light is on, door switch continuity checks out.i can hear the timer running,but motor does not start. verified power to motor while motor was unplugged.what next?
  • BUBBA GUST Nov 04, 2007
    i HAVE THE SAME PROBLEM !
    DRYER WILL SHOW THAT THE FABRIC SENSOR COMES ON WHEN YOU PULL THE START SWITCH ON FOR A SECOND OR 2 THEN SWITCHES OFF .
    Problem Solver:
  • 9 Answers
Change the copasitator this tells the machine to engage the motor
Posted on Dec 06, 2007
Maytag bravos won't run sensing light is on
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
https://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
http://www.partselect.com/Repair/Washer/Will-Not-Start/
http://www.partselect.com/Repair/Washer/Will-Not-Start Washing Machine Repair Help
Jan 06, 2017 | Maytag Washing Machines
I have a Maytag LDE9304ACM dryer. It suddently quit today. When I press the start button, the start button light "lights up", but there is not sound and no rotation. I can hear the timer. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2011 | Maytag Dryers
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Dryer wont start
Push on the door switch and make sure the light goes out. When the light goes out, a contact should be made to allow the motor to run. If you can get to the timer, spray a good electronic contact cleaner inside while rotating the dial. While you have the unit open, vacuum out all the lint, and check for loose wires, especially to the door switch.
Apr 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
Apr 04, 2009 | Maytag Atlantis MAV7000
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Maytag Dryer won't run
Maytag Atlantis Series MDE6400AYW --
Current is good, brand new power cord, drum light comes on --
When I turn the timer, I can hear it clicking, but nothing else works.
Aug 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Sep 22, 2007 | Maytag PYE2300AY Electric Dryer
Dryer not running has current
zedlast Did you check the door switch? If the door switch is fine, reset the circuit breaker. If it does not help then check the power cord connection to the dryer. One of two hot wires could be loose or burned out. If nothing of the above helped, let me know. Gendos...post back
Mar 03, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
94 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
