Question about InFocus LP70+ Multimedia Projector
Need image to show on both the HP laptop and the InFocus IN15
Hitting FN F4 three times should put the image on both the laptop and the projector, but the image just flashes on the projector and then shows blue w/ no image. So to summarize, we can get the image on just the laptop and just the projector, but not on both. We have checked the resolution and that does not appear to be the issue. Any ideas?
  • 2,237 Answers
Make sure the laptop is plugged in and not on battery. also make sure the dmi-vga cable is not too long. the signal isn't strong enough to get to both screens.
Posted on Aug 10, 2009
How to connect lp540 projector to hp computer
If using an laptop press and hold the FN key then press F4 or F8 and you may need to try this more then once to get it to the proper setting you need. If you are using a desk top with only one VGA output then should be just the cable and good to go, but if you are using two VGA outputs then you may have to configure the setting in control panel-display properties, for the 2nd monitor (projector).
Jun 25, 2014 | InFocus LP540 LCD Projector
Infocus in15 temp and lamp indicator flashing
In attempts to get your IN15 projector working, please try the steps below.
Disconnect AC power from the projector and wait for 10 seconds for supply to properly discharge.
While holding down the Menu, Select and Input buttons simultaneously, plug in the main AC power until
the LEDS stop flashing (approximately 7 seconds)
Jul 15, 2012 | InFocus IN15 DLP Projector
Connecting laptop to projector
Connecting an External Monitor or Data Projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCD screenplus the external monitor or back to LCD screen only by pressing the Fn keyplus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Jun 05, 2012 | HP Pavilion dv6200 Notebook
My hp probook 4510 not connecting to projector, was working before
CONECT AND CLICK( FN )AND (F4) KEYS FN ARE INSIDE OF A SQUARE THE F4 MAY BE IS THE KEY TO ACTIVATE PROJECTOR YOU HAVE TO SEE THE IMAGE LIKE A SCREEN A SQUARE AND TWO LINES ONE ON RIGHT SIDE AND ONE ON LEFT SIDE
Nov 25, 2010 | HP Computers & Internet
First time using infocus 1x projector with this laptop - installed drivers but there is no start up screen on the projector and will not display laptop image.
You have to tell the computer you hooked up an additional external monitor. Lower left on the keyboard you will see a "FN" key. Across the top, your F keys...look for an icon that looks like a monitor. Usually F5, F7 or F8. Hold down the FN key and select the F5 etc key which is the command to display the image through the external port. Doing this once displays image through the projector and laptop. Twice displays image to projector only and three times returns to display only on laptop again.
Jun 19, 2010 | InFocus LP640 Projector Multimedia...
Cannot seem to get simultaneaou screen with HP laptop when using the fn+f4 function
TURN OFF THE COMPUTER AND AS IT START6S MAKE SURE THE PROJECTOR IS SET TO COMPUTER SIGNAL AND AUTO SEARCH. USUALLY TURNING ON THE COMPUTER WILL CREATE THE SCREENS IMAGE AND YOU ARE DONE.
Jan 19, 2010 | InFocus Office Equipment & Supplies
Is there an alternative to the
You can try powering off the laptop, connect the projector, power on the projector, then power on the laptop. Sometimes it can boot directly to the screen of the projector if detected at startup.
Another option could be to attach a USB keyboard to your laptop and use that to press the Fn + F4 keys.
Jan 14, 2010 | Computers & Internet
Video projector from a laptop
You can connect the Projector to the VGA Port of the Notebook which is a Blue Port which can be seen at the rear of any desktop computer to which we usually connect the Monitor to.
The VGA Port will have 15 holes on it and should be in Blue colour.
You can locate the VGA Port at the Left side of the Notebook.
Locate the port according to the information available below :
http://h10032.www1.hp.com/ctg/Manual/c00726464.pdf
Refer to page number 14 (18 of 32) in the manual.
Once you connect the Projector to this port, hold the FN key and press F4 key once.
This wil get the Display on the Projector connected to the Notebook.
If you just want the display only on the Projector, hold the FN key and press the F4 again.
Now, if you want the display back on the LCD of the Notebook, Press the FN + F4 third time.
Hope this helps..
Aug 31, 2008 | HP Pavilion dv2000t Notebook
Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Jun 19, 2007 | InFocus X1 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
128 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
