Question about Epson Stylus C66 Inkjet Printer
HP Photo Smart 1215/1115 condition shows PAUSE. How do I make it return to ACTIVE?
You're reply referred to the Epson Printer On my HP Photo Smart 1215/1115 Printer I went to START then in the window I went to Faxes and Printers then in a new window I found RESUME PRINTING!! It changed Pause to Active.
Posted on Jun 06, 2009
I want to make my lg 500 go dvd region free how do I do it!
1. Power on (with no disc inserted)
2. Press PAUSE
3. Press 3, 1, 4, 1, 5, 9
4. Enter the desired RC
5. Press PAUSE
6. Turn the player off and wait a few seconds.
1. VCD playback
2. Press PAUSE, 1, 4, 7, 2
3. Press UP 6 times, '07 00' should appear on the display
4. Press Program 6, Program 5 ('07 FE' should be displayed)
5. Press ENTER
6. Press RETURN
7. Power off and on again
If you wish to get some details; check the site linked here. Pull up older posts.
Sep 02, 2016 | LG Hr925m 500Gb Smart 3D BRay Player And...
What does it mean that printer is on "pause"
This means that print jobs sent to the printer will not print untill the printer is unpaused. This setting is used mainly for maintenance purposes.
To unpause a printer
1.) Left click Start in the bottom left hand corner of the screen
2.) Left click Control Panel
3.) Now, double-click "Devices and Printers" or "Printers and Faxes"
4.) In the Window you will see your printer, double-click your printer
5.) This screen will show you active print jobs, to pause or unpause the printer click File then click "Pause printing"
Hope this helps :)
May 15, 2011 | Epson Stylus C66 Inkjet Printer
Needs to reprogram fax machine, has old fax numbers in
1. Press Menu/Set, 2, 3, 1.
2. Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3. Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter a pause in the dialing sequence (for example, to wait for an "outside line"), press Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing Redial/Pause enters a 3.5 second pause when the number is dialed.
4. Use the dial pad to then enter the name (up to 15 characters), and then press Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name, press Menu/Set.
5. Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or, if you haven't stored a name, the number you've stored.
If you loose electrical power, auto dial numbers in memory will not be lost.
(For USA Only) One-Touch key 1 has been pre-programmed for the Brother faxback system. One-Touch key 2 has been pre-programmed for the CallManage long distance plan. You can override them if you wish.
Note If you need to store a pause longer than 3.5 seconds, press Redial/Pause two or more times.
Note - You can store Groups (for Broadcasting) on the One Touch keys.
Dec 11, 2010 | Brother IntelliFax-2820 Laser Fax
We lost our manual and I am trying to reload our speed dial numbers. I have tried everything but can't seem to figure it out. Help?
1 Press Menu/Set, 2, 3, 1.
2 Press the One Touch key where you want to store a number.
3 Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter
4 Use the dial pad to then enter the name (up to 15 characters), and then press
press Menu/Set.
5 Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
Dec 07, 2010 | Brother IntelliFax-2820 Laser Fax
Sx4t labels gap setting
1. Press the [PAUSE] button. The display shows the printer is in PAUSE mode.
2. Press the [PAUSE] button again. If the display shows TRANSMISSIVE then release the [PAUSE] key.
3. Press the [PAUSE] button again. Labels will now start to feed through the printhead. After 5 or 6 labels have gone through, release the [PAUSE] key.
4. Press the [RESTART] button.
The printer should now be on line and if you press the [FEED} key, 1 label should be fed through.
Aug 21, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
How to get a photo to pause
View Individual Photo
1. On the photo thumbnail screen, use ? / ? to highlight a photo and then press ENTER to view it individually.
2. Press EXIT to return to the photo thumbnail screen
Mar 18, 2010 | PANDIGITAL 6.0-Inch Digital Picture Frame...
Cannot print from hp5600 all in one.
1) we will check that printer is start or pause.
2) If first condition is correct,then OPC drum is filled or not.
3)If both conditions are right, then there should be Hardware problem .
Apr 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Epson Stylus C66 Inkjet Printer Logo
189 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
