Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Heater pilot sticks
I have a teledine laars heater on my pool in my house that u just purchased.. my issue is the pilot light is sticking to the point were i cant even turn to light the pilot... i did use wd-40 to attempt to loosen the valve with no luck... any thoughts?
  • 24 Answers
Just replace the valve all together, sounds like its seized and dont mees with it just get a new one for safetys sake.
Posted on Jan 24, 2010
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light stays on but burners will not come on.
open safety within circuit, poor electrical connection or tstat issue
Oct 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
When lighting my LG model furnace the pilot will light but when I turn the gas knob to ON after holding in the pilot position for the minute it goes out and will not stay lit. What parts do I need to...
Thank you for posting your question here on Fixya.com.
The pilot generator most likely; if not there is a short in the gas valve and it will need to be replaced. Generators are a normal wear-and-tear replacement part...gas valves are not. The generator should be under $40 and is pretty easy to replace. Some places call the part the thermocouple but either name works. It is the metal 'stick' with a metal-clad set of wires from it the sticks up next to the pilot flame and is in turn heated up by the pilot to power the rest of the heater.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Mar 03, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
Larrs lite llg natural gas heater - the only way i can light the pilot is to remove the valve knob and push the valve pin in manually - that lights the pilot everytime but when the pin is released, the...
This is a problem with the thermo-pile. Yoiu need a 750 millivolt general replacement thermopile. You can purchase at your local HV AC supply store. Should cost about $45
Jan 23, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will light but heater will not ignight
You may need to replace the Ignition Module. Have someone check to see if it is sending power. I have the same problem and need to replace the Fenwal automatic ignition system. The part cost $390 - check inside the heater for the model #
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Laars pool heater, model R0096400, and I can not get the pilot switch to push down to lite it. asked a pool service guy come to fix, he could not move it too, and told me that i need a new valve....
your pool guy may be right but before spending any hard earned cash,remove phillips head screw in middle of on/off/pilot knob and remove.make sure there is no debris under knob.squirt spray lubricant along stem wait 10 minutes and lube again.replace knob turn to pilot position work it by pushing down several times.it may stick in down position so gently pry up.my success rate is about 70/30 for this technique
Jul 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Jun 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
82 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
