Question about Coffee Makers & Espresso Machines
I need a manual / handbook for a fracino classic 1 group auto machine. Does anyone know where I can get hold of one? thanks
3 Suggested Answers
wiqi546
  • 1511 Answers
SOURCE: I cannot find the screw
Hello Alex, I hope you remember me, we just had a Live chat session on Fixya, I have send you an Exploded view for the Machine, so that you can find out which bolt is troubling.
I request you to please Login back to your FixYa account and on the top right corner you will see a 'My Profile' link, go there and find the chat we had, (you can see the link to the file there)
And IF you think I was helpful, kindly leave some feedback after accepting the solution, as that will be useful for FixYa's future reference.
I hope you will spare some time for this. I will feel obliged.
Regards, WAQAR.
Posted on Dec 27, 2009
  • 1089 Answers
SOURCE: My brew group is jammed.
Hi
Its on the left inside of the brew unit. There is a hole on the left side of the brw unit. That hole is to access the screw in the normal position but now it has mover. You will have to go in from the side. Its a #1 Phillips screw. You will need a 6" screw driver.
Here are the directions you will need.
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. If you have you key you can insert it in the front of the brew unit. There is a round hold in the center below the “Push”, and twist it clockwise until it stops and the 2 marks are lined up. If you don’t have your key you can do this. Push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Press the “Push” lever until you hear a click and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted, and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now insert the brew group, and replace the tray. If it still won’t go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Posted on Jan 06, 2010
Anyone know if Platinum 730 handbook is available
Try the Viking website under 'Machine Updates' (bottom right hand corner of home page), information is available on all machines, including user manuals/guides. You will need to select your machine from the Machine Updates page. If it is not listed, select All Machines for a complete listing.
May 31, 2014 | Husqvarna Viking 1
Flashing ready and water
Hi u machine looks like a fracino cherub if thats the case it sounds like the inlet solinoid open it up take it out its a littel blue box siral strip it make sure theres nothing blockin
g it test power to switch if all ok its the inlet solinoid switch 28.50 + vat. 6.50 POST from fracino hope I helped?
Feb 11, 2013 | Coffee Makers & Espresso Machines
Fracino little gem coffe machine manual
visacrem intternational limited
FRACINO COFFEE MACHINES
THE LITTLE GEM
INSTALLATION INSTRUCTIONS
.REMOVE PLASTIC BUNG & FILL TOP TANK WITH COLD WATER TO TOP (N.B WATER SHOULD BE SOFTENED)
.PLUG MACHINE IN & SWITCH ON AT MAINS
.TURN MACHINE ON (ON/OFF SWITCH ON SILER PANEL JUST UNDER FRONT RED PANEL- NEXT TO GROUP)
.RED NEON AND AMBER NEON LIGHTS WILL ILLUMINATE AND THE MACHINE WILL START TO FILL
.OPEN STEAM VALVE (TURN RIGHT HAND BLACK HANDLE ANTI CLOCKWISE)
.WHEN WATER LEVEL REACHES THE YELLOW LINE ON THE SIGHT GLASS THE LIGHT WILL GO OFF AND
THE MACHINE WILL CUT OUT
REFIL THE TANK AND THEN TURN THE ON/OFF SWITCH OFF AND WAIT 5 SECONDS TURN THE ON/OFF
SWITCH BACK ON THE MACHINE WILL CONTINUE TO FILL
.WHEN THE WATER LEVEL REACHES THE TOP RED LINE ON THE SIGHT GLASS THE RED LIGHT WILL
GO OUT THE AMBER LIGHT WILL REMAIN ON UNTIL THE WATER REACHES THE CORRECT LEVEL AND THEN
GO OUT
.THE MACHINE WILL NOW START TO HEAT THE WATER WAIT FOR STEAM TO COME OUT OF THE STEAM TUBE
(BETWEEN 5-10 MINS APPROX) AND CLOSE THE STEAM VALVE (TURN RIGHT HAND BLACK HANDLE CLOKWISE)
.WAIT FOR THE PRESSURE TO COME UP TO 1-2KG/CM3 (PRESSURE GAUGE ON FRONT OF MACHINE BETWEEN
THE TWO BLACK HANDLES)
.THE MACHINE IS NOE READY TO USE
.PUT EMPTY FILTER HOLDER INTO THE GROUP AND FLUSH WITH WATER BY TURNING ON RED SWITCH NEXT
TO PRESSURE GAUGE AND LETTING WATER RUN THROUGH THIS PROCESS WILL TAKE SOME TIME AND USE
APPROXIMATELY HALF PINT OF WATER THE GROUP AND FILTER HOLDER SHOULD BE HOT - CHECK BY
TOUCH IF THEY ARE NOT HOT LET WATER CONTINUE TO FLUSH THROUGH UNTIL THEY ARE AND THEN
TURN RED SWITCH OFF
.MAKE A TEST CUP OF COFFEE THIS FIRST CUP WILL PROBABLY BE COLD BUT AS YOU MAKE MORE CUPS
OF COFFEE THEY WILL GET HOTTER IF POSSIBLE LEAVE THE MACHINE TO STAND FOR APPROX 30 MINS
BEFORE MAKING COFFEE THIS WILL ENABLE IT TO WARM UP AND PRODUCE COFFEE AT THE CORRECT
TEMPRATURE.
HOPE THIS IS WHAT YOU WERE LOOKING FOR ITS WHAT THEY GAVE ME WHEN I GO MINE FROM THEM.
IF NOT HERES A LINK TO THE PARTS MANUAL AND CATALOG
http://www.fracino.com/technical/parts.html
http://www.fracino.com/machines/hand-fill-coffee-machines/little-gem.html
http://www.vendingexpress.co.uk/uploads/pdf/product-fracino-little-gem-automatic_4e7a1df44be5d.pdf
Jan 20, 2012 | Coffee Makers & Espresso Machines
The brew group is stuck half way thru the brew cycle and now it won't finish making or dispensing steam. How can I unstick the group?
Hello Teresa,
I understand that the brew group is stuck in your Expresso Machine. Did you know that it has to be removed and cleaned ever so often. The users manual explains how to reset and remove it for cleaning. Incase you no longer have the users manual here is a link to the users manual http://www.cerinicoffee.com/custompages/Manuals/Saeco/IncantoClassic_Manual.pdf
Thank you for using FixYa.com
Justin
Mar 11, 2011 | Saeco Incanto Classic Espresso Machine
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
Hi , Im looking for a handbook/ users manual for Audi A4 2005 2.0 tdi avant. Anyone know where I can download one? Thanks
You can look for Haynes Repair Manual for your car, they are mostly sold on any auto repair shops or auto zones, or order it online. I'm not sure if you can find any pdf format of it though. Hope this helps
Feb 14, 2010 | 2005 Audi A4
Have just dual fuel fracino, but the cups are
emailed fracino direct, explained the problem and they told me exactly what it was and how to sort it ,, so happy now
Jan 30, 2010 | Coffee Makers & Espresso Machines
I was given a gaggia 87003 expreso deluxe machine ,and cant find an operators Manuel.Do you know how to use it ?
Check out this site use the manual for the classic, it is virtually the same machine.
groups.google.com/group/espresso_worlds/files?hl=en
Oct 09, 2009 | Gaggia Espresso De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
302 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
