Question about Brother HL 1430 Laser Printer
Lexmark t420 all leds are on
When i turn on ,, the printer,,  in the secuence all leds are on,, an i can't print,, can u help me?
    New Friend:
  • 159 Answers
What this light sequence means:
• The printer is processing a request to cancel the current print
job.
• The printer is resetting to the user default settings. Any active
print jobs are canceled. A user default setting is one you select
and save which is different from the factory default setting. A
user default setting remains in effect until you make another
selection and apply it or until you restore factory default settings.
What you can do:
Wait for the message to clear. It clears when the printer finishes
processing the cancellation request or when it resets to the user
default settings.
Posted on Mar 11, 2008
LexMark e321 printer is printing blank pages. I changed out the ink toner, reinstalled the driver from the E321 disk, changed the USB cable and still get 2 blank pages and the LED button by error is...
Try to disconnect all cables from the printer and leave it off for about 30 seconds to clear the print job. Turn the printer back on and check the status lights, error light stop blinking then try connecting the printer back to the computer and try printing again.
For further assitance, please contact Lexmark Technical Support
Jul 20, 2011 | Lexmark E321 Laser Printer
My Lexmark E250DN : 02 led on the right hand is ON, the system restart and can not print. Any suggestion for help???
The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
You can press and release Continue button to clear the light sequence and continue processing the print job. Turn the printer off and remove the toner cartridge, and shake it to extend the life. If toner light is on, replace the toner cartridge.
For further assistance, please call Lexmark Technical Support.
Jan 11, 2011 | Lexmark E250dn Laser Printer
I need to reset the NVRAM
Resetting or reinitializing the network card's NVRAM will clear all TCP/IP configuration information. To have a record of this information, it is recommended that you print a network settings page prior to performing the reset procedure. Press pattlnk_8302006_1627-e120con.jpg to print both printer and network settings pages.
  1. Turn the printer off.
  2. Press the left front cover release button and pull the front door down.
  3. Press and hold pattlnk_8302006_1721-e120can.jpg while powering the printer On.
  4. Release pattlnk_8302006_1722-e120can.jpg when the pattlnk_8302006_1723-exclam.jpg LED is illuminated. NOTE: Be patient as the LEDs will light up in multiple patterns before finally stopping at pattlnk_8302006_181-exclam.jpg
  5. Close the front cover. NOTE: Observe that the pattlnk_8302006_1735-e120con.jpg, pattlnk_8302006_1735-rdydta.jpg, pattlnk_8302006_1736-tonrlow.jpg and pattlnk_8302006_1739-rmvpr.jpg LEDs will be illuminated at the same time. This is known as the Home position.
    OPTION: Have the customer hold down pattlnk_8302006_1735-e120con.jpg to print a "Printer Diagnostics" menu page.
  6. Slowly press the pattlnk_8302006_1743-e120can.jpg button until the pattlnk_8302006_1750-rmvpr.jpg, pattlnk_8302006_1847-tonrlow.jpg, and pattlnk_8302006_1748-rdydta.jpg LEDs are illuminated. NOTE: Normally, this will require you to press the pattlnk_8302006_1743-e120can.jpg button 11 to 13 times, depending on the options and features installed.
  7. Press and hold pattlnk_8302006_1754-e120con.jpg until all LEDs flash or strobe from left to right, then release the button. Wait until this process stops with a pattern of three LEDs that should resemble the Step 6 pattern.
  8. Press and hold pattlnk_8302006_1844-e120can.jpg until the light pattern returns to the pattern of four LEDs in Step 5 or theHome position.
  9. Turn the printer Off.
  10. Turn the printer On.
    NOTE: If on a DHCP network, wait 30 seconds to see if the DHCP server/router sends out an IP address to the device. A settings page will automatically print if this is successful. A longer wait may be required on other networks.
  11. Press pattlnk_8302006_1814-e120con.jpg to print the settings pages and observe that all the TCP/IP settings have been reset.
  12. Reconfigure the device using DHCP, Auto IP (zero configuration) or the IP Setup Utility.
Hope this helps.
Jun 22, 2010 | Lexmark E260 Laser Printer
E120 Laser Printer: my Lexmark e120 printer doesn't printing at all, n...
You may need to replace your photoconductor unit. Part number 12026XW
May 17, 2010 | Lexmark E120 Laser Printer
Printed pictures comes out red
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Lexmark Optra Color 1200 Led Printer
I have a Lexmark T420 that I want to connect to my new laptop (HP) via a parallel to USP. The print drivers will not load. What do you suggest?
does it have to connections to the printer like a usb and a paralel cable, this is a cable that has two big ends on it and just a straight cable . if there is you might be able to do this by usb, and it will also depend on what os you are useing
thanks
hope this works for you
Aug 21, 2008 | Computers & Internet
Lexmark C912 dn LED laser
one of your print heads ahve failed ie printhead leds the but you uuslly find the printer lies so you may have to replace several of them
Jun 20, 2008 | Lexmark C912 Led Printer
Lexmark t630 frozen
I can provideyou with the procedures to default the printer. That may help.
1. start with the printer turned off.
2. Press and holde the GO, Select and the Right Menu Arrow buttons while turning the printer on.
3. Hold the button in until the display show "RestoringFactory Defaults" then let go.
4. The printer should come back to a Ready state.
Feb 07, 2008 | Lexmark T630 Laser Printer
Mirrored printing
I WOULD REPLACE PHOTODRUM usually this will fix it
Jan 17, 2008 | Lexmark C912 Led Printer
T420 error lights
does this occur after while, during or after printing?
from what application are you printing?
sounds like the print you are sending may be too big for the memory of the printer, or it can not recognize the file type.
Oct 16, 2007 | Lexmark T420d Laser Printer
Brother HL 1430 Laser Printer Logo
581 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
