Question about Samsung J700 Cellular Phone
Does the Samsung J700 phone have a replaceable small black plastic part in the top left hand corner when lokking at it from the front.I recently dropped mine and a 'bit' described above came off and exposed a metal pin. It looks like the piece that came off is just like an insert and can just be put back in but of course I can't find to do so. Is this right is there a detachable piece in the top left hand corner? and if so where can I get it?
  • 421 Answers
Sir please go to samsung mobile service centre
Posted on Jun 04, 2009
Recently, i buy a samsung galaxy S GTI9003 and there is some applications that i want to remove but i can't.please advise.
Open the menu of your Samsung phone. Click on the "Edit" button on left corner top corner of the screen.
edit-samsung-wave-menu.jpgAs soon as you click on the edit button, you will see a red colored icon on the installed apps.
remove-samsung-wave-apps.jpgClick on the red remove icon on the installed apps to uninstall them. Once you are done uninstalling the apps, click "Done" on the top left corner of the screen.
That's it you are done with the process of uninstalling apps in Samsung phone.
Regards
Jun 28, 2011 | Cell Phones
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Voice dialling sgh j700
Hi I am a software repairer, Luckily I have a J700 belonged to a customer.
SORRY It was specified but not included.
You can use Hands Free Long press Hands free button and do it.
May 09, 2010 | Samsung J700 Cellular Phone
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
SMS
to turn off predictive text go into messages-select- create new -select-message-text message-select then press and hold the * key and you will see in the top right corner it changes from ABC to abc or T9. to send sms messages go to settings -select -application settings-select-message-text message-select-sending options-select- GSM alphabet then maximum then text.
Hope this helps.
Sep 09, 2009 | Samsung J700 Cellular Phone
How do i get a photo to facebook from my mobile?
hi the samsung phone u have connect it to pc vear usb if not u should have micro sd card in left hand of mobile
start take ur photo connect mobile v usb to pc
create a new icon folder on ur desktop-rename icon for u click write mouse options rename click type whatever just click now drag photo to ur renamed folder then goto face book open ur profile in top left hand corner uplode photo
click scroll to desktop and find ur folder double click u should see it now click and wait problem solved email me if u have a prob dave
Jul 04, 2009 | Samsung J700 Cellular Phone
How do you get fast text on samsung j700
Is that "predictive text"? if so: when in a message, press and hold the * key until you see T9 in the top right hand corner that shows Abc etc
Feb 22, 2009 | Samsung J700 Cellular Phone
Fitting instuctions for replacing lcd screen on my samsung e250 mobile phone
ok...
1.take off battery cover, remove battery, memory card and sim card
2. remove the five screws on the back... two at the bottom, two in the middle and one on the mid top right and take off this cover, remember! keep the screws safe
3. slide the phone up and take out the two screws on the left and right paralel with the battery tabs then remove the two screws ether side of the camera...they might be covered by rubber coverings, these pop out easily
4.now you can prise the top of the screen off with a small flat headed screwdriver
THERE ARE TWO OPTIONS HERE, IF THE REPLACEMENT SCREEN HAS NO RIBBON CABBLE ATTACHED THEN FOLLOW FROM FIVE, IF IT HAS ONE CONNECTED THEN FOLLOW FROM
5. its conected to a ribbon cable, remove the tape and slide out the cabble from the screen.
6. now take out the screen PCB from the plastic casing and replace it with your new one and put the ribbon cable in and clip it back together, now reverse stages 3 to 1 to put it back together.
7. if the ribbon cable is attached now you must look at the PCB board on the back for a square copper line, on the left of this there is a big black square just smaller than the copper square, prise this off with your finger nails, keeping it to the side take the PCB up about 2mm and then fold the bottom of it to revele it is conected to a ribbon cable by a bigger version of the black square so prise this off and take the PCB and put it safely to one side.
8. look on the front of the phone under the top bit of the screen, there should be a semi circle in the plastic with a black circle in the top of it, use your nail or a flat headed screwdriver to pop it to the other side of the semi circle, now the slider should go past what it used to o you can slide it up to when you can see the ribbon cable go down through the phone, now push the black square end through and you should be able to slide the whole front off.
9. replace the screen by taking the screen PCB out and repacing it, then thread the ribbon cable back through and slide the front on while making sure the back circle goes into the semi circle and to the top side of it, then thread the black square through the phone to the front and clip the phone front back on.
10. snap the black square back on to the back Circuit then put the circuit back into the phone and snap the small black square back on then go from stages 3 to 1 to put it back together.
this should be fairly easy to do for most people.
Jul 03, 2008 | Cell Phones
Samsung J700 Cellular Phone Logo
60 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
