Question about GE Washing Machines
I have an older GE Washer model s1070a1ww it will not spin out
Its like there is a belt off or a jam. It tries to spin but will only move about a half an inch
  • 20 Answers
SOURCE: Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Posted on Jan 27, 2008
  • 489 Answers
SOURCE: Walking Washer
The best way to fix this problem is to adjust the front legs while the machine is spinning a full wash load.  Put in a load of clothes and run the machine to get the clothes nice and wet.  It will take about 5 minutes to get them completely wet.  Next, turn the washer off.  Now, turn the washer back on and push the spin button to select the extra fast speed.  You washer will go into a drain mode and then begin to toss the load into a balance spin mode.  Once the washer is spinning the clothes, check the balance of the unit by pushing the front left corner of the washer towards the right rear corner and right front corner towards the left rear corner.  If the sound of the washer quiets down on one side vs the other side, adjust the front leg to quiet that side.  Do not attempt to adjust the rear legs as they do not require adjustments at all.  Everything adjusts on the front legs.
This procedure works if the floor is sturdy enough.  If the floor is old and the wood is weak, it will not work.
Posted on Apr 27, 2008
onthejob5130
  • 640 Answers
SOURCE: my 30 year old GE compact washer won't spin
easy,,avanti.com..
Posted on Jan 12, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
SOURCE: ge adora top load washer won't spin,
the water in my washer will not empty, and it keeps pausing its self.
Posted on Sep 30, 2009
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Ge washer WJSR4160DAWW will not spin will agatate
FIRST IS ALL THE WATER BEING PUMPED OUT? SOMETIMES IF IT IS NOT THE SPIN WILL BE SLOW. ALSO CHECK BY LOOKING IN THE BACK OF WASHER THAT NOTHING IS CAUSING A DRAG ON THE TUB. CHECK THAT THE BELT IS NOT LOOSE AND SLIPPING.
May 06, 2014 | GE WJSR4160DWW Top Load Washer
Dryer not spinning
sounds like you have a bad motor, most likely do the vent being restricted or partially clogged for a long time.
Feb 27, 2014 | GE Washer Repair Video Older Models
GE washer WPRE6100G0WT not agitating or spinning
Depends on how old the machine is. It might me a transmission problem
Jul 25, 2012 | GE Profile WPRE6100G Top Load Washer
Tub will spin but agitator won't move on my ge washer model wpsr3090v0ww
IF it sounds like it is agitating but isn't moving, check to be sure the agitator is still firmly bolted to the transmission shaft. If it sounds like it's stuck when it tries to agitate (belt slipping possibly, etc.) it is probably a bad transmission and often not worth repairing unless you can find a used one somewhere.
Dec 31, 2009 | GE WBSR3140DW Top Load Washer
Will not agitate or spin, belt is fine. Motor is not turning, just making a humming noise. Is the motor bad or are there brushes that can be replaced or.....?
move the belt to see if it is not jammed and spins the rotor. If that is the case, the Humming noise is then an indication of a burned motor and not from a good motor trying to drive a jammed belt.
Oct 09, 2009 | GE WJSE3110A Top Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Non-spinning washer
Have you checked the motor? Make sure that the motor is turning properly and also make sure that your belt it not to tight. It should have some give in it. If none of that works then look at the main bearing under the pulley on the drum
Feb 10, 2009 | GE WNSE6280BWW Top Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Washing Machines Logo
241 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
