Please detach all non-essentially accessories from your tv before turning it off and on from the remote. If the issue persists, please power cycle your tv (ie unplug for 30 seconds and then replug). Please check multiple channels to see if the issue persists. If so, you can then reach out to your tv-channel provider to ask if there's a local service-loss in your area that is being worked on currently.
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
If still under guarantee take it back. If not this sounds like a workshop job. If more than five years old (the TV, not you!) and you can afford it, junk this set and get a new one.
Yes you can do this.
You just need to make sure that the TV outputs its picture on the scart lead that you have connected to the Pioneer unit, and you need to set the Pioneer unit to record from that scart input.
Once this is done, it will be able to record whatever you have on the screen.
Be aware though, if you turn off the TV it stops outputting its picture to the recorder, and if you change channel, it changes what what the recorder see's too.
I hope this helps you. :)
This sounds like you may have a bad color wheel. If you want to change this yourself you need to be aware that even with the tv unplugged there are still dangerous voltages in the set. Changing the color wheel is an involved repair the wheel it's self is very fragile to handle, they can be purchased on line from many sources.
The cost from a service center would be a normal service charge plus about $150.00 for a color wheel. If you have a service center come out to your house explain your problem clearly and they will know they need to bring a color wheel, it will prevent the tech from having to make a second visit.
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
I've had a couple of these. The panel control board is going bad, but there may be a way to make it last a bit longer. If you go into the MENU of the TV, and turn off all the color correction, all the whistles and bells that come inside the tv to "make the picture better," it usually helps. Any kind of motion correction, or any kind of noise reduction (picture noise reduction) should be turned off. If the picture has a cloud of green pixels that seems to pepper the screen, then after you turn off all the stuff in the menu, unplug the TV for 5 minutes, and then plug back in. It should help the picture some.
I have just run into the same thing, prior to the picture not coming on there was a loud whining noise, I thought it was the fan in the back, but, what I tried was removing the lower back panel, LIGHTLY tapping the light wheel assembly just left of the Bulb housing, and using a shop vac to first, **** the assembly around the edges and then reversing the air and Blowing it out. After much dust and dirt flying around the TV came on. It now only makes a little noise now and then, but, I will try this again today and then put the back panel back on. Since it would probably cost as much as a new TV for the color wheel, I gave this a try. For now, it is working.
Mr. Wizard
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder.
2004 - SC-D107
2003 - SC-D5000, SC-D27
2002 - SC-D180
Recording In Player Mode
1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device)
2. Set the power switch of the camcorder to PLAYER mode.
3. Turn on the VCR or TV.
4. Insert the blank tape with protection tab closed into the camcorder.
If you want to record from a connected VCR, insert a recorded VHS tape into the VCR.
5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button.
6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN.
"AV IN" and picture appears on the LCD monitor.
OUT : Releases the INPUT mode.
7. Press the START/STOP button to set the camcorder to REC PAUSE mode.
"PAUSE" appears on the LCD monitor.
8. Select the TV program or playback the VHS tape.
9. Press START/STOP button to start recording.
If you want to pause recording for a while, press the START/STOP button again.
10. To stop recording, press the (STOP) button.
Notes:
* Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed.
* If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
