Question about Sony BRAVIA KDL52XBR2 Television
Sony bravia kdl52xbr2 problem
My Sony kdl52xbr2 is less than one year old.  The tv goes black with streaks of blue, green, and yellow.  The audio still works, just not the screen.  What are my options?  How can this be repaired?  Any advice would be appreciated.
Thanks
sktbin
  • 1,113 Answers
12 month warranty. dont know your country, here (Oz) your tv's warranty includes in home pick up
check sony.com and use model number, kdl52xbr to search
Warranty Terms and Conditions – Includes Standard and Extended Warranty for the following products:-
Bravia LCD TV/ Grand Wega LCD Rear Projection TV
Standard Warranty Terms and Conditions
1.1 Subject to the terms and conditions set out below Sony agrees to repair or replace at Sony’s cost the Sony product, and any Sony accessory supplied with it, purchased by you in Australia or New Zealand from a Sony Authorised Dealer (Product) when the Product does not perform in accordance with the manufacturer's specifications during:-
(i) the Standard Warranty period is 1 Year from the date of purchase; and
(ii) the Extended Warranty period specified (if purchased in accordance with section 2.1 below).
1.2 Proof of purchase (i.e. bill of sale, invoice or purchase receipt) must be presented when requesting service under the Standard or Extended Warranties.
1.3 Sony reserves the right to replace the Product or relevant part with the same or equivalent Product or part, rather than repair it. Where a replacement is provided the Product or part replaced becomes the property of Sony. Sony may replace parts with refurbished parts. Replacement of the Product or a part does not extend or restart the Standard Warranty period. Replacement of a part during the Extended Warranty period does not extend or restart the Extended Warranty period. If the Product is replaced during the Extended Warranty period, the Extended Warranty automatically terminates upon replacement.
1.4 Included in the Standard Warranty for Australia & New Zealand is an in-home pick-up service for television receivers with screen sizes greater than or equal to 67cm provided the pick-up address is within 25kms of the nearest Sony Authorised Service Centre.
1.5 Included in the Extended Warranty for Australia only is an in-home pick-up service for all products listed, except where expressly excluded, and provided the pick-up address is within 25kms of the nearest Sony Authorised Service Centre.
1.6 The Product will be at the owner’s risk whilst in transit to and from the Sony Authorised Service Centre, unless transported by Sony or its Authorised representatives.
1.7 Sony and its Authorised Service Centres may seek reimbursement of any costs incurred by them when the Product is found to be in good working order.
Posted on Dec 18, 2007
  • 170 Answers
Hi,hoping that the cable connections are right(check the cable connections once again)..... Sounds like you may have a problem with the video driver boards? I would call up the store where you bought it and ask for a new set or service on this one.
More than likely this is a bad display (lcd screen) the drivers in the lcd display have some problem...... the tv is just a month old so you are still under the warranty period....... just contact the sony outluet where you purchased or the manufacturer for servicing of tv
Sony Bravia KDL46W4150 crackles and volume suddenly increases
Hello
There is some loose solderings or leaky ceramic capacitors at the audio output section of your sound card. Check it.
Feb 28, 2012 | Sony BRAVIA KDL52XBR2 Television
I have purchased Sony Bravia LCD BX 42, which has a very thin horizontal line across the screen, how to fix the problem
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
Aug 29, 2011 | Sony BRAVIA KDL52XBR2 Television
I have a black approx 12 inch streak on the left side(facing tv) of my flat screen Bravia Sony TV . It is approximately 3 years old. It started as a brown panel..then became a fine lined multy colored...
sadly you have a bad panel. Sony panels carry a two year warranty.
your best hope is to call Sony and ask for a warranty extension to cover the cost of the part.
Apr 12, 2011 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
May 06, 2010 | Sony Bravia KDL-46VL130 TV
The color is off. Everything looks either green or yellow.
This is a light engine that is failing and a VERY common issue. Contact Sony because the warranty on these light engines was extended until June 30th of this year under bulletin E30020889. It is probably worth it as a consumer to call and see what they will do for you since this was really a design flaw. Please take a few moments to rate my answer. Thanks...
Nov 20, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Connect cablebox/dvr to sony bravia
try yellow cable into the green y input.
http://en-americas-support.nintendo.com/app/answers/detail/a_id/3008/~/unable-to-locate-a-yellow-video-input-on-the-tv
The problem is that av output is going into component in
If the green port doesn't work I read on another forum that
you may be able to use a dvd recorder unit to take the av in and then it can re transmit the video to an output as component out on some dvd recorders.
Apr 29, 2017 | Sony BRAVIA® DAV-HDX576WF Theater System...
Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
Jun 11, 2008 | Sony BRAVIA KDL52XBR2 Television
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony BRAVIA KDL52XBR2 Television Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
