Question about Macromedia Flash MX
I want to do on slides buttons next and previous, what i have to write there
How to make power point presentation
The PowerPoint software program allows you to create slide presentations that can be viewed on any computer.
While some graphic artists specialize in developing compelling presentations, anyone can develop a PowerPoint slide presentation that is attractive and readable.
Follow these steps to develop your own slide show.
Open your PowerPoint program. When the dialog box opens, click on the "Blank Presentation" option.
Choose an "AutoLayout" format.
Begin with the title slide layout, which is the first one on the left. Click "OK," and you will have a title slide to work with.
Add text to your slide by clicking in the title text box and typing a title.
Do the same thing in the subtitle box.
Create another slide by clicking the "New Slide" button on the Common Tasks toolbar.
When the AutoLayout dialog box appears, choose a layout for this slide.
Keep adding new slides until your presentation is complete.
Move from slide to slide by clicking the button on the lower-right corner of the PowerPoint window.
Clicking the button with the upward-pointing arrows will take you to the previous slide, and clicking the button with the downward-pointing arrows will take you to the next slide.
Save your presentation. Click the "File" menu and then click "Save As."
A dialog box will appear, and you'll be able to type in a name for your presentation.
The presentation will be saved to your hard drive.
as for the kreb cycle disgram im not sure
hope this helps
Oct 15, 2012 | Computers & Internet
I have a Philips PD7030 portable dvd player and want to make it region free. Can you help me?
Turn on your DVD without any disc.
In the blue screen, press the rectangular buttons: next, previous, next, previous, next, next, previous and will appear a configuration menu.
Scroll up to Region
Press OK (Play)
Scroll up to Test 0
Press OK
Press Right arrow to exit
Jan 09, 2012 | Philips Televison & Video
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
My swimp3 will not go to previous song when I hit the previous button. When I hit the Next button, it will go to the next song; however, the previous button will only go to the song that is currently...
There will be a 4-7 digit number stamped on the backside of the USB stick when the cap is removed, can you provide this number please? Also you can try double tapping the previous button, for with the new Firmware update the units have received this is the standard function. If you have any other questions feel free to contact me directly a mmoss@finisinc.com.
Jan 22, 2011 | Finis Swi MP3 Player
We have a La Cimbala M2 barsytem that indicates press cleaning button, where is it?
The top left button on the 2nd row of smaller buttons. It has a filled cup as an icon. press and hold until screen says 'short wash' or group wash. There is also a full cycle washing that is required some time during the day usually at night or start of a work shift. This requires the opening of the 'de-cafe' or pill drop chute. It's a small black slide about the size of a pack of gum. open it and drop a cleaning pill then close it. the panel buttons will blink and the screen will say press cleaning button. press and hold the wash button (as previously mentioned) till the cycle starts to clean. Release button and allow 8 mins for the cycle to complete. This will keep the 'clean cycle' clear until the next shift or next day when it needs to be done again. These instructions should be in your manual that came with the machine.
Sep 27, 2009 | Espresso RMI La Cimbali Espresso Machine
New browser windows open to the right of the previous one.
Instead of opening a new IE browser for each site, try using the Tabs at the top (blank square next to the Website title). (see below)
You can also Right-Click on links on web pages and select "Open Link in New Tab". This should also help your computer run better as opening new browser windows uses more memory.
Feb 05, 2009 | Dell Vostro 1700 Notebook
The pictures on my sansa mp3 8gb
I didn't realize the sansa clip supported pictures - are sure you posted in the right section?
Just giving you a hard time. If you have a Sansa Fuze 8GB:
Looping a Slideshow
1. Press Submenu button while viewing photos.
2. Scroll to Loop and select it.
3. Use the thumbwheel to select Loop on or off.
4. Press the Select button.
5. Press the |<< button to return to previous menu.
Specifying the Slide Duration
1. Press Submenu button while view photos.
2. Scroll to Slide Time and select it.
3. Use the thumbwheel to highlight and select the desired duration (from 2
seconds to 30 seconds).
4. Press the Center button.
5. Press the |<< button to return to the previous menu.
Selecting Slideshow Music
2. Use the thumbwheel to highlight Slideshow Music and select it.
3. Select Current Song (if a song is currently playing) or Music Go List
(plays music from the Go List) then press the Center button.
4. Press the |<< button to return to previous menu.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Problem with MP3 player-Stops after one song
On closer look (after my long road trip to test this out), I realize when you hit Browse, there's a button on the bottom titled Play All. If you select this button, the buttons mentioned above work as intended, and the Forward, Backward buttons bring you to the next or previous songs in the list.
Sep 27, 2008 | Garmin Nuvi 660 GPS Receiver
Visual Basic
Hi Buddy,
Create 2 buttons for previous and next in a form(say, current_form). take the previous form as 'prev_form' and next form as 'next_form' then
write a code in the previous button command click event as
prev_form.Show()
current_form.Hide()
write a code in the next button command click event as
next_form.Show()
current_form.Hide()
Please let me know if you have any concerns
Sep 02, 2008 | Computers & Internet
Macromedia Flash MX Logo
44 people viewed this question
Top Macromedia Computers & Internet Experts
Tony
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
