Question about Car Audio & Video
Unlock code please for a 2006 GMC Canyon 6 disk cd player
Had to have the cd/radio replaced. Of course it dosn''t work with out the unlock code. The dealership wants $100.00 to do it.
  • 87 Answers
Try this it should work for you.
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed.
2. Write the numbers down.
3. Press the AM/FM button, write down the next 3 numbers.
4. Call 1-800-537-5140, when asked, enter 620529, press the # button and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM/FM button, SEC should be displayed, turn on radio.
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Posted on Jun 04, 2009
Locked radio 2006 gmc canyon
Most modern cars have a security code enable for the installed radio/cd players. This is an anti-theft device.
The initial documents given to the owner when the vehicle was purchased lists this code and how to reset it.
If you are second owner/original owner who has lost this information, then, you can approach gmc canyon dealer and they will have this code on their server. Normally a free service (I believe).
The security code is lost from the radio whenever keep alive voltage is removed from the radio. i.e. You disconnected or replace the battery.
I hope this helps.
Jul 23, 2014 | 2006 GMC Canyon
I have a 2004 canyon the cd player wont work and shows initualizing on screen whats wrong and how do i fix it
radio receiver going bad, will need to have gm dealer remove and install replacement radio, radio has to be programmed by gm dealer
Sep 03, 2012 | 2004 GMC Canyon
Cd player is not reading cds what can i do to repair it.
Subject: Radio With Six Disc CD Changer Does Not Recognize Loaded CD And Displays An "INITIALIZING" Message, CD Will Not Play, CD Cannot Be Ejected, Or Disc Icon Does Not Illuminate (Reprogram Radio)
Models:
2005-2006 Chevrolet Avalanche, Suburban, Tahoe
2005-2007 Chevrolet Colorado, Express, Silverado Classic, TrailBlazer
2005-2006 GMC Yukon, Yukon XL
2005-2007 GMC Canyon, Envoy, Savana, Sierra Classic
2005-2006 HUMMER H2 with Six Disc CD Changer Equipped Audio System (RPO UC6)
Condition
Some customers may comment on any of the following conditions:
• The CD loaded in the radio will not play.
• The CD loaded in the radio will not eject.
• The disc icon on the radio will not illuminate.
• The radio displays an "INITIALIZING" message for approximately 30 seconds after vehicle start up.
Important: Do not attempt to play CDs with paper labels on them in this CD player. The labels may warp or wrinkle and jam the CD player mechanism. Refer to the Compact Disc Care and Cleaning procedure (Document ID# 1656123) in SI for more information.
Technicians are to reprogram the radio with new operating software using the following procedure:
1. If the radio has a CD(s)2008 General will be necessary to reset the radio and remove them
before the radio is reprogrammed. Remove and reinstall the radio fuse to reset the radio and then eject the CD(s). If cycling the power to the radio does not allow the CD(s) to be removed, the radio may have another failure that will not be corrected by the reprogramming procedure that follows. Refer to the Diagnostic Starting Point - Entertainment procedure in SI to begin your diagnosis of this failure to eject CDs concern before reprogramming the radio.
2. Reprogram the radio using the Service Programming System (SPS) with the latest software available on TIS2WEB. Refer to the SPS procedures and the Radio Programming and Set procedure in SI for more information. As always make sure your Tech 2® is updated with the latest software version.
3. Verify proper operation of the radio and make sure that all CDs can be ejected.
Hope helps (remember to rate this).
Oct 03, 2010 | 2005 Chevrolet Trailblazer Ext
How to enter the unlock code on the 6 disk cd changer
Look on the side of the glove compartment, there is a sticker with numbers, that is your code. In general, the number from 1 to 6, so you simply enter your code by using the existing buttons.Hope this help.
May 03, 2009 | 2006 Honda Odyssey
I have a 2006 Yukon xl Denali with the Bose radio/ Navigation and separate 6 disc cd changer. The am/fm radio works fine, but when using XM, the channels get stuck and have to be turned manually.
generally it would just need to be reset... unhook the battery for about ten minutes and hook it back up. make sure you have the unlock code for the radio FIRST and you know how to enter it.
Robert
Feb 17, 2009 | 2006 GMC Yukon Denali
How Do I find out if My 2005 Canyon has the Bose system or not?
sounds like a standard system to me but i think the bose has little tags on all the speaker grills that say bose
Jan 09, 2009 | 2005 GMC Canyon
CD Player Quit Working
the only thing i can sagest is that you leave the battery disconnected over night this may reset the cd player and it may Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Recognise that it has cds in it
the only other thing i can think of is that when it says enter single disk only that you do so to a point don't let it go all the way in
this may make the cd player think there is a disk in there
hope this helps
ricko
Dec 28, 2008 | 2004 Chevrolet Malibu
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
Dec 14, 2008 | 2006 Pontiac G6
Remove radio/cd from 2004 GMC Canyon
Check out Crutchfield.com. They have detailed instructions on how-to install radios in your Canyon.
Dec 09, 2008 | 2004 GMC Canyon
Locked renault clio 2001 cd/radio player!
to enter your code when the cd player displays error leave cd player switched on and after 20 mins or so i will display 0000 then you will be able to enter your code this happens when some 1 has entered the wrong code
May 17, 2008 | 2000 Renault 181
Car Audio & Video Logo
567 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
