Question about Garland H283 Gas Kitchen Range
Our Garland range Model RC283-IR, seems to have a problem with the oven thermostats. It is always way under temp or way over. Any way we can get it checked out and adjusted? Also, while it says "0" clearance between the sides and nearby combustible surfaces, the metal sides seem to get extremely hot when the oven is on. Thanks for your thoughts. Bill S.
3 Suggested Answers
  • 3 Answers
SOURCE: change thermocouple Garland range
I know the question is a little older, but maybe it helps someone else... I just did the job and it turned out to be much easier than I thought it would be. The whole burner assembly slides out, so you don't have to work in that small space!
Simply turn off the gas, disconnect the two pipes that go from the oven to the valve (gas and thermostat), disconnect the two door springs from the burner unit, remove the screw that holds the valve, remove the two screws that hold the burner in place and simply slide the thing out. You may have to loosen the right half of the heat protector plate to get it out. That's it.
Posted on Nov 12, 2009
dcramer531
  • 1654 Answers
SOURCE: I have a commercial garland
The model of this stove is
Model G60-6R24RR
There are slightly different versions and they have some small differences but the guts will all be the same parts. Here are the other versions.
G60-6R24SS
6 Open Burners, 24" Raised Griddle/Broiler w/ Double Storage Base
G60-6R24RR1
6 Open Burners, 24" Raised Griddle/Broiler w/ (2) Standard Ovens
G60-6R24RS1
6 Open Burners, 24" Raised Griddle/Broiler w/ (1) Standard Ovens & Storage Base
I can't help you with a local dealer or repair but here are some links to the stores that carry parts.
http://www.webstaurantstore.com/
just go to the site and look under equipment parts and then thermostatic controls. And dig of your part there.
Or try here, http://www.partstown.com/
http://www.etundra.com/
http://www.tmeinc.biz/xgarland.htm
This last link will take you to the thermosta itself, just click on the first thread on the page.
Posted on Aug 05, 2011
I have a Garland Sunfire 36 inch gas Range. oven does not come on again after reaching temp.
You probably have a bad thermocouple. Try cleaning it off with sand paper. It's the part that the pilot light is igniting.
Mar 15, 2012 | Garland SunFire SX-10-26 (Gas) Stainless...
Where can i get parts for a garland starfire gas oven
Our oven pilot light will not stay on - we have to relight all the time. We have had the thermocouples replaced already and it is only two years old. The seller will no longer work on it for us. Says it is our fault in that we MUST be doing something wrong.
May 13, 2010 | Garland H286 Gas Kitchen Range
Pilot relighting Garland Commercial range
The main burner valve is the oven valve. The pilot will be next to the burner and you either have to insert a long shiskabob stick ( lit) into the hole or lift up on the bottom of the oven (inside) and you will see the pilot.
Feb 09, 2010 | Garland H286 Gas Kitchen Range
Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Mar 04, 2009 | Garland H283 Gas Kitchen Range
Garland oven does not work
Hi, it is hard to tell for sure, but it sounds like your safety device, the component that keeps the pilot lit, may have failed, allowing gas to the pilot, but not letting gas through to the burner. See your manual on/off valve lets gas to the thermostat, then through the thermostat down to the safety, because you wouldn't want gas to get past there if there is no pilot, and now that part is stuck open, but the rest of the part is not engaged to open and let gas continue to the burner. There is an easy way to tell, under the bottom panel, is a part with a red button ( the safety ) and connected to it is a copper looking tube, or the thermocouple, it can be disconnected by unscrewing it from the safety with a wrench, if the pilot goes out, your safety is mostly working, if not, it is bad, and needs replacement. Let me know, hope that help, and thank you.
Jan 05, 2009 | Garland H283 Gas Kitchen Range
Garland 6 Burner Oven
Garland have there own web site for ranges , 6 burner garlands are used in catering . AS for repairing it don't know . Its not that hard I have done a few most parts are good to get .
Jun 08, 2017 | Garland H284-24G Kitchen Range
Oven will not maintain temp.
your fdo stat may be out or failed
May 20, 2008 | Garland H286 Gas Kitchen Range
We want to refurbish the old Garland stove in our church kitchen.
Hi, I am sure you can still get the thermostat replaced, however, it is unlikely anyone will service the unit without oven safeties, for insurance/liability issues. You may be able to get it updated with these devices, but I would bet that you could find a newer used unit that is in fair to good shape for the same or a little bit more money. You can contact Garland range at www.garland-group.com, call 1 800 424 2411, or look in your phone book in "restaurant equipment repair" for a company to advise you, and "restaurant equipment sales" for new/used equipment. Check on ebay for approximate prices if you are curious. Hope that helps, and thank you.
May 05, 2008 | Garland H283 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
123 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
joneable
Level 1 Expert
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
