Firing order for rocam1.6
A six cylinder in-line engine has a power impulse every 720 degrees/6 i.e. 120 degrees of crankshaft rotation. The crankshaft has six crank-throws placed at 120 degrees out of phase with one another, which can be arranged only in three planes. Therefore, the crankpin phasing is arranged in pairs. For heavy-duty diesel engines, seven journals and bearings are provided, at each end and between adjacent crankpins. For petrol engines only 4 or 5 main journals are provided. The firing order with the crankshaft arrangement shown in the attached figure is considered. With piston 1 at the top of the compression stroke, its opposite piston 6 is at the top of its exhaust stroke. Rotation of crankshaft through 120 degrees brings pistons 2 and 5 to their TDC and either one of these can be arrangement to complete a compression stroke. If piston 5 is arranged to be at the end of compression and at the start of its power stroke, then piston 2 must be on its exhaust stroke. Rotation of crankshaft through second 120 degrees positions pistons 3 and 4 at the TDC, so either one of these can be on the compression stroke. If piston 3 is made to be on compression, piston 4 must be on its exhaust stroke. A third rotation of 120 degrees brings pistons 1 and 6 back again to TDC, where piston 6 is arranged to be on the compression and piston 1, therefore, be on its exhaust stroke. A fourth 120 degrees rotation brings pistons 2 and 5 to their TDC. Piston 2 is now on its compression and piston 5 on its exhaust stroke. Rotation of crankshaft through fifth 120 degrees brings piston 3 and 4 to TDC. Piston 4 is on compression and piston 3 on its exhaust stroke. Final rotation of 120 degrees completes the 720 degrees displacement of crankshaft and brings the pistons into positions for the next cycle. This cycle provides a firing order of 1, 5, 3, 6, 2, 4. If the phasing of paired crank-throws 3 and 4 and 2 and 5 are interchanged, then a second equally suitable firing-order of 1, 4, 2, 6, 3, 5 is achieved. This arrangement provides excellent dynamic balance and evenness of torque, and is preferred for engines larger than 2.5 liters provided length is not a prime consideration.
am using the tool that you need to push down on and rotate the piston. This does not use the c clamp to depress the piston.
Yes i am aware of the right caliper piston needing to be turned counter clockwise. Also there is an arrow indicating that. I did get the job completed by removing the caliper which depreassureized the caliper and then i was able to turn the piston. Job is complete and brakes are operating well.
The solution was part of the answer. I needed to remove the piston and drain the caliper so i could turn the piston to get it back into the caliper.
Are you compressing it with a C-clamp?
