Question about IBM ThinkPad T20 2647 Notebook
Ibm laptop 2647 series23 the power is on no monitor screen lite
I have a ibm laptop 2647 series23 the power goes on and runs but the montior screen does not go on.
  • IBM Master
  • 32,281 Answers
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 04, 2009
Thinkpad blank screen
Once you run safe mode. You can turn off the laptop. Then start booting normally.
Mar 02, 2012 | IBM ThinkPad T20 2647 Notebook
My IBM Thinkpad screen has gone dark but I can still see a bit. Is there a key to brighten the screen?
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Aug 29, 2010 | IBM ThinkPad T23 2647 Notebook
My think pad goes dark after the windows logo...
Right click on te screen and click on properity in the screensaver tab check the power setting to make sure it is not set to hibernate if so un check the boxs and check the shutdown time
Apr 21, 2009 | IBM ThinkPad T20 2647 Notebook
Ibm laptop t23
Your laptop is in sleep mode. Hence the z. Push your power button for 5 seconds, and the unit should turn off, and be able to boot properly.
Feb 11, 2009 | IBM ThinkPad T23 2647 Notebook
Monitor is blank when we turn the computer on.
Maybe not. Find the FN key. It is usually BLUE in color
Then look on TOP row of Computer keyb (or all over) and find CRT/LCD.
Press the FN and that key and your screen should come back. You accidentally sw. it to CRT (outside, external monitor)
Jan 14, 2009 | IBM ThinkPad T23 2647 Notebook
Black Screen
mostly like is your lcd screen...you can try to see if your laptop still working by connect to external monitor.
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Technically Black Screen
when u power up the system press F8 key untill u get safe mode menu.
then goo to enable vga mode set your resolution to 800*600 or 1024 * 768.
also u can try safe mode or last known good config.
White screen Ibm t 23
Have you tried switching the LCD monitor from teh good thinkpad to the ones with white screens? Sometimes its the actuall LCD.
Mar 16, 2008 | IBM ThinkPad T23 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
185 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
