Question about Sharp LC-26GA5U 26 in. HD-Ready LCD Television
Vizio plasma screen has 2 red lines
Two red lines down the center of my vizio. I have done some research, and apparantely it is due to a defective part vizio used. The replacement is like $280. I cannot afford it. It started out as one line down the center. Now there's another line that appeared today about a half of inch next to the first one. If I don't pay to get it fixed, what will eventually happen? Will I soon lose the screen completely?
If anyone knows, please tell me!
  • Tony Nguyen May 11, 2010
    does the line move with different channels or inputs? if not your panel is getting bad and that is not repairable unless the panel itself is replace.
  • 80 Answers
The power supply in these sets have had bad electrolytic capacitors which short and actually blow their top because of increased pressure. Only part of the switching power supply is now running so you may see a power light but nothing else. I am not sure what Vizio would charge to replace the cap or supply. If this is the case, we would charge for 1 hour labor ($120.00) and for the capacitor ($3-4.00)unless the manufacturer recommends replacement of the power supply. Hope this helps you. Joe Weibel Custom Electronics (
Posted on Feb 14, 2007
SOURCE: RE: Vizio P42ED Plasma TV
Just took the unit apart recently haven't tested the heat sinks and I don't see any error codes. None of the video inputs work but I do get sound from the RF input audio. I have not connected anything to the RF video input for actual video but will try. Right now I'm guessing it is the main input video board but the part nunber on the board does not match that of the parts distributor.
Posted on Dec 08, 2007
SOURCE: Horizontal green line appears on screen
my maxent plasma tv has the same problem but it has green and red lines. I found out that hitting the tv from the back works. It used to last a long time but now i have to get up now and then to slap the tv on back with my hands! anyone with a long term solution?
Posted on Jun 12, 2008
SOURCE: My Sharp Aquos
Why does my sharp Aquos TV go out of resolution everytime I turn off the Wii game that is hooked up to it? Then I can reload Optimum cablevision- all I get is the program guide. Help
Posted on Nov 21, 2008
  • 150 Answers
SOURCE: Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Posted on Dec 03, 2008
Vizio vertical line
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | Televison & Video
Vizio display issues
Screen turned black except vertical color lines in the center
good day your vertical ic is defective needs to replace look for qualified technician to fix your tv
Jun 20, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Thin red line down the center of my screen
I'm afraid you'll need a tech on this one.  It could be the panel itself which would be beyond economical repair. If you're lucky it may be a bad connector/connection.
May 17, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Black line in centr of Screen
sounds like a bad panel, try reseating any cables you can on the buffers . the buffers would be on the lower edge right where the black line appears. unfortunately Vizio does not supply panels.
Jul 28, 2009 | Televison & Video
My vizio 37" plasma tv has a green line running down the right side of the screen
Vizio does not make 37" plasma TV. for the green line problem, does it happen on all inputs or just when you what TV (cable or satellite)? That line should only be present on some channels due to signal processing compatibility. To get rid of it, you can use the horizontal size adjustment and expand the picture side way.
Jul 03, 2009 | Vizio L37 Television
We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
Jun 13, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have red lines up/down on my Vizio, how can I correct this?
Your sympton need to be more specific, but if what you see is 1 or more tiny lines running from top to bottom of screen (verticaly) and those lines change colors (red/green) depending on the background color on the screen, then your control board need to be replaced, you will need your TV model and product code, both located in the back of the TV next to serial number
Jun 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Red line down right side of screen
I would have a tech come out and look at it. Sometimes the ribbon connectors from the upper or lower buffer boards have poor or corroded contacts. Should'nt be a major deal since it comes and goes.
Apr 21, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Plasma tv red strip
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
Dec 21, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Sharp LC-26GA5U 26 in. HD-Ready LCD Television Logo
411 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
