Question about Lands Phones
I cant connect my blackberry with my pc - Lands Phones
    Scholar:
  • 47 Answers
If you purchased your Blackberry new, it should have come with a cable (usually micro usb to standard usb), and a driver/software disk. This allows the BB to both connect to the PC and charge. Depending on the model, it won't charge without the driver installed, even though you may get a small icon that says you're connected.
Also - the Blackberry desktop software will allow you to syncronize your contacts.
You can download the software for your model from blackberry.com
Posted on Jun 05, 2009
Tip
Load applications onto your blackberry.
<span> <p>To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an <span>application</span> called <span>blackberry desktop</span><i> Manager</i> (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.<span>Accessing the Blackberry Application Loader</span>After BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:<span>1. On your PC, select Start --&gt; Programs --&gt; BlackBerry --&gt; Desktop Manager.</span>BlackBerry Desktop Manager opens.<span>2. Connect your BlackBerry to your PC via your USB cable.</span>Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.<span>3. Enter your password.</span>This completes your BlackBerry-to-PC connection.<span>4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.</span>The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.<span>Using the Blackberry Application Loader</span><br /> <p> <span><span><span> <br /> <span> <p>To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your PC.you can install it on your BlackBerry by using Application Loader as follows:<span>1. Launch Application Loader from BlackBerry Desktop Manager.</span><br /> <p>The Application Loader Wizard welcome screen appears.<span>2. Click the Next button.</span><span>3. Enter your password, and then click Next.</span>If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.<span>4. Click the Add button.</span>An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.<span>5. Locate the ALX file and then click Open.</span>You return to the Handheld Application Selection.<span>6. Click Next.</span>Doing so brings up the confirmation screen, listing the application to be installed.<span>7. Click Finish.</span>The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry<br /></span></span></span></span><br /></span>
on Nov 23, 2010 | Cell Phones
Blackberry playbook hanging
Apparently it needs to be reformatted. Connect it to your computer and use the blackberry software on it to RESTORE OR UPGRADE the OS on the device.
Dec 27, 2012 | RIM Blackberry Playbook with 64GB Internal...
Bb bold toggle cant select the icon
try n download a new RIM/firmware for blackberry bold 9000 and use 'apploader' to install it on your blackberry.
The 'apploader' is located at the program file in your PC only if u have installed Blackberry desktop manager on your PC.
Search on google on how to install the fimware.. it is very easy and simple
Aug 19, 2011 | RIM BlackBerry Bold 9000 Smartphone
I cant connect my cell to internet through connecting to laptop.i wnt 2 connect 2 internet via laptop by using my ph as a modem
You may find problems with that. BlackBerry now have stopped that feature on their software as it is being abused.
Speak to your local Phone Shop for advice.
Jan 23, 2011 | Computers & Internet
I just cant get my blackberry curve to pair or sync
Do you have blackberry desktop manager with you.If you have connect your phone with USB Cable to pc then start the application in your PC then click OK if you receive any warning message.
Type the password of your cueve device.
Click the "synchronization" option in the column of the left side of the screen and then "synchronization" button on right
Type the password if you configured in your phone
Select data which you want to sync.Contacts,messages etc will automatically sync,
I hope this help you
Thank you
Sep 30, 2010 | RIM BlackBerry Curve 8310 Smartphone
I hv a blackberry 9000 phone and the red light blinks but I cant switch on the phone even thouh its connected to a power adapter for charging
Take the phone off charge and take off the battery on the phone, you can now put the battery back into the phone. Press and hold the red power button on your phone. If the problem persist then go ahead and download the blackberry desktop manager unto your computer. Connect your blackberry to the computer and initiate the blackberry desktop manager. Once it shows connected as status between the phone and your BDM (blackberry Desktop Manager). Reinstall the software on your blackberry. Make sure the computer is connected to the internet.
Regards
Jan 24, 2010 | RIM BlackBerry Bold 9000 Smartphone
Internate connection on pc
I assume you are trying to use the Blackberry as a modem and connect to your computer to connect to the internet. It is possible. All you need is a data plan from your servcie provider and the desktop manager software. In case your CD that came with the device is unusable, you can freely download the software from your service provider's website. Once the software is downloaded, run it and connect your Blackberry to the computer and then set the modem settings as detailed in the link below:
http://www.blackberryforums.com/blackberry-guides/2019-user-howto-use-blackberry-modem-laptop.html
Dec 28, 2008 | RIM BlackBerry 7290
No owners manual
how to insertsim card in the 3g iphone
Jun 30, 2008 | Computers & Internet
Blackbery8310
its a security feature with blackberrys. its a good thing if u have important info on there but otherwise it can really ****. sometimes itll work with Blackberry to Blackberry
May 15, 2008 | AT&T Blackberry Curve 8300 Smartphone
Lands Phones Logo
107 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
