Question about Microwave Ovens
Panasonic genius premier 1000w microwave - how to change interior light bulb.
  • Anonymous Mar 22, 2014
    The tune table will not turn around
  • Microwave Ovens Master
  • 9,047 Answers
The first step is to unplug the oven before changing bulbs!
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can usually download your Panasonic owner's manual here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jun 06, 2009
Whaqt are the dmensions of panasonic genius premier model number nn-s7768a
Here's your answer and then some, in case it helps
Brand: Panasonic
Name: The Genius Premier 1000W
Primary feature: reheating of popular food categories is done automatically (time and power level automatically determined, often time adjusted based on steam sensor). Defrosting also done by entering weight (so time is automatically determined).
Color: black matte top/lateral sides; black gloss front; white back; silver bottom
Style: Counter/table top (label says not for mounting)
Model: NN-S7768A
Manufacture Month/Year: September/1996
Dimensions Exterior: 14"T x 23-3/8"W x 16-1/2D (18 including protruding door handle and back cord plastic clip)
Dimensions Interior: 10-5/8"T x 16-1/4"W x 15-1/4"D
Cubic Feet interior: ~18.28 cu ft (based on three interior dimensions multiplied together and divided by 144 to get from cubic inches to cubic feet)
Note:
I found a manual from a similar model; you'll probably want to pring page 15 as a reference, since each food category button has 2-4 modes based on the type/temperature of the food, e.g. veggies are 1. for potatoes up to a certain quantity and weight each, 2. fresh veggetables of a certain weight, and 3. frozen vegetables of a certain weight. Specific instructions on adding water, covering, etc. are also included. Makes microwaving pretty easy!
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CGAQFjAB&url=http%3A%2F%2Fservice.us.panasonic.com%2FOPERMANPDF%2FNNS696.pdf&ei=BMEnU4-RLaWbygHQ2oCQCg&usg=AFQjCNF2JlFATy7HV-Ltv0BjDUf_LHHi3g&bvm=bv.62922401,d.aWc
Jun 24, 2013 | Panasonic Microwave Ovens
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
Microwave stuck in demo mode
try unplugging it for 10 minutes. Otherwise, try looking at the instructions:
service.us.panasonic.com/OPERMANPDF/NNC994S.PDF
Sep 14, 2009 | Panasonic NN-C980 Convection/Microwave...
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Glass plate and int light failed - is this a fuse fail ?
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Dec 06, 2008 | Panasonic NN-S753 Microwave Oven
I have a Panasonic microwave oven model # NNL 939 (1000w) that is what is stated on the booklet. My problem is that both oven lights went out and want to know how to replace them.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Nov 07, 2008 | Panasonic Microwave Ovens
Panasonic genius microwave light bulb replacement The bulb on my Microwave model RMC275PD blew and no the microwave won't start, if I replace the bulb will the microwave work again? Thanks Richard
Yes definitely that should be working fine again since it only stop working when the bulb blew,so go ahead and replace the bulb so you can use it again...
Hope that helps.......
Aug 27, 2008 | Whirlpool RMC275PD Microwave Oven
Panasonic Dimension 4 the Genius Microwave/Convection NN-C888W I cannot seem to get into this to replace the electric light bulb. Please can you help me.
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
Apr 30, 2008 | Microwave Ovens
Microwave Ovens Logo
2,701 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
