Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Loss of transmission power after 15 minutes
Craftsman DGT 4000 Unit mows fine for 15 minutes when cold. Shortly thereafter transmission stops moving the unit. Blades still turn. Just cant move. Did the air purge as the manual says but did not help. Could It be low on trans Fluid? If so where do I add. Believe its a sealed unit. Any Help would be appreciated. Thanks
    Novelist:
  • 153 Answers
If you don't have an oil spot under the transmission in your parking spot you probably don't have a leak. It is far more likely that the idler pulley is frozen. Is is on a spring loaded lever toward the front of the tractor, made of plastic, and if your take belt tension off it, it should spin freely. If it is bad, you can easily get a new one from sears.com.
Posted on Jun 04, 2009
Is the Craftsman DGT 4000 model # 275242 with kohler liquid cooled engine any good
I am a professional within the industry. I am just going to say spend your money elsewhere...
Nov 24, 2013 | Garden
My craftsman tractor will only mow for about 10-15 minutes then won't move.the transmission oil is okay and it is hydroststic driven
In my dealings with hydostat drives, the forward-reverse valve is bad or the pump itself. When it is cool the hydraulic oil is thicker but thins as it heats up, letting it get passed the bad seal(s) causing low pressure!
Aug 28, 2013 | Craftsman Garden
Craftsman dgt 4000
Broken gear at the end of the steering linkage, or broken teeth, also check to see if the stationary gear mounted to the tractor itself isn't broken off or worn out.
Jun 08, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
97 mustang power loss at 4000 rpm seems like it wants to go but won't doent do it when cold only after runing for about 15 minutes seems like it bogs down
Sounds like a weak fuel pump or clogged fuel filter.Check your fuel pressure it should be 30-45 psi with key on and engine off.
Feb 24, 2012 | 1997 Ford Mustang Cobra
I need a belt diagram for the mower deck on a Craftsman DGT 4000 mower w/ 48" deck... Can you help??
If you go to sears.com and click on parts. You will need to enter your model number-not dyt4000-but the model number on the machine's ID plate, probably with the serial number.
It will respond with your mower parts diagram!
May 07, 2011 | Craftsman Garden
Craftsman lawn tractor model 917.270821 ( Auto trans)
Check the fluid level in the transmission. If the fluid level is low, the trans will act as if it's slipping.
Nov 25, 2009 | Vacuums
Intek 6.5 HP in a Craftsman 21'' mulcher/bagger --loss of power--
No - 6.5HP is enough to cut 3" at a fast walking pace. I would suspect a blown head gasket.
Sep 26, 2009 | Garden
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
421 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
