Question about Ovens
My indesit electric oven cuts out after about twenty minutes, will not switch on again until it cools. is this caused by a faulty thermostat?
  • andydavis25 Jun 05, 2009
    Thanks for reply. Fan appears to be working fine, can feel air coming through vents at the top of oven. Any more advice would be much appreciated
  • Ovens Master
  • 3,463 Answers
It is probably the overheat safety thermostat that is operating due to oven overheating.
Check to see if the top cooling fan is working, and if it is built in, make sure it has adequate ventilation.
Please rate my advice.
Thankyou.
Posted on Jun 04, 2009
We have a fan oven, which started not heating, but fan and thermostat light still on! We thought it was the element! But now the oven is working very occasionally, still heating as normal! We can try to...
Elements don't heat intermittently - if the element is good it will heat up every time. If the element is blown / burnt-out it wont ever heat.
As your oven is heating sometimes but not others, this means the power supply to the element has an interruption somewhere. This could be caused by any of the following:
1. Loose connection in the wiring at the switch or the element
2. Faulty switch
3. Faulty thermostat.
4. Faulty oven timer
The thermostat is effectively just a heat-sensitive switch. By default it should be "closed" allowing power to the element. When the oven reaches the desired temperature, this switch opens, cutting power to the element until the oven cools enough for the switch to close and allow power to the element again.
Any of these four could be the cause of your fault. Loose connections can often by located visually, however testing a thermostat for correct operation and calibration is more complicated and ideally requires test equipment. The timer is the least likely cause, so I would concentrate on the others first.
Repairing your oven or any other electrical appliance can be dangerous and many repairs require specialist knowledge and/or electrical test equipment. Please bear this in mind before and when attempting any repair or consider having your appliance professionally inspected.
If you are intending to investigate this problem yourself, please ensure the power is disconnected at the wall/breaker first. Initially, I suggest that you visually check the connections at the element and the switch. You may find a wire at one of these locations that is partially broken or detached. Personally, I suspect your thermostat may be faulty.
Hope this helps.
Regards,
BElectric
Jan 01, 2011 | Ovens
OVEN OVERHEATING
thermostats are not the sane. make sure cooling fan is working as this is more likely to cause the oven to cut out
Jul 23, 2010 | Electrolux EOD6390X Electric Double Oven
My AEG B3101-4 oven works for about 30 mins, then seems to cut out... it won't work at all until it has cooled down, and then the cycle starts again... can you tell me which part is likely to need...
It is a safety thermostat that is cutting the oven off, due to overheating.
It could be that the external cooling fan is not working, or the cut out itself is faulty.
Check to see if you can hear the fan working.
This is usually located on the top of the oven , at the rear of the oven, on the top .
Hope this helps.
Dec 13, 2009 | AEG B3101-4 Electric Single Oven
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
Dec 31, 2008 | Baumatic B180SS And B60SS (Bundle)...
Aeg b3101 oven / grill cutting out
Ther are a couple of possibilities that could be causing your problem.
A thing called the safety stat could be cutting the oven out, it is designed to cut off the oven in the case of overheating This is what brings on the cooling fan. Sometimes they cut out prematurly for example you may not have enough vetilation, check for restricted or blocked vents.
The stat itself could be faulty again causing the oven to cut out,and then as it cools down it resets itself and so on and so on.
The thing to do after you hve checked evrything else is toichange the stat.
It is usually located on the top of the outer oven compartment, it is about 1" or so long with a feed in and out of it
Plz rate my solution.
Thanks, and merry xmas.
Dec 20, 2008 | AEG B3101-4 Electric Single Oven
My oven turns off on me after only a minute never heating up fully
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Oven heats up then switches off
there is an overheat stat in the oven which turns it off if overheating. the causes are several. 1 - oven thermostat is faulty and oven is reachingf too high a temp. 2 - there is a second fan in the casing to keep the casing cool. 3 - this second fan is turned on by a fan start stat which may be faulty and is not starting the cooling fan 4 - the overheat stat itself is faulty. it is a bit difficult to narrow it down from afar. get back to me if you want
May 19, 2007 | Electrolux EOB6636X Ultrafan Electric...
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
Ovens Logo
300 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
