Question about Coleman Powermate Premium Plus 6250W Portable Generator
Engine works but no power is produced
I bought the coleman 6250 and the motor works but after an hour of use the gen stopped producing power the breakers are not tripped and I don't see any loose wires.  Any ideas?
I have a COLEMAN 6250 Watt Powermate too, and it stopped producing 3 hrs into our blackout. I unbolted the four 7/16" bolts holding the end bell assembly, and looked at the circuit board (bridge rectifier assembly) and saw that 4 of the diodes had melted free from the circuit board. This is a $30 replacement part, and seems to be a common problem with these units. http://www.jackssmallengines.com/coleman_control_board.cfm
Other common and cheap to fix problems may be the brushes are worn out. Unscrew the phillips screws under the plastic tab on the end bell of the generator, and pull out the metallic rectangular posts attached to the copper wires. If they are shorter than 1/4", broken, or uneven, they may need to be replaced. They are about $3 each.
I probably drew too much power from 1 outlet on the generator, and it caused the board to fail instead of tripping the circuit breaker. (BTW, the repair shop told me it would cost $550 to replace the entire rotor/stator circuit board assembly. I have a strong feeling they didn't even look at any of the above parts, because they didn't have a clue as to what they were doing!)
I liken this to taking your car in because it won't start, and the mechanic saying you need a new engine!
Posted on Jun 27, 2009
    Sergeant:
  • 149 Answers
Yes to all of the above, but also I have found that the exciter windings can burn an open circuit and will need rewound. This seems to be a fragile generator.
Posted on Jun 28, 2009
I've got a coleman 6250 that runs great! Motor wise that is. There's apparently no electricity coming out, and the brushes are new. I'm at a loss...any suggestions?
Shut it off, restart. May have condensation. This happened to me with a generac. OH! OH! OH! Check your fuses! Generator will start, but produce nothing MAY just be a fuse.
Oct 02, 2016 | Coleman Electrical Supplies
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
My Coleman power mate 6250 does not produce 110 voltage from generator to camper plus the outlets and resets buttons does not work
Your field has lost the residual magnetism. You need to flash the field. There are several ways to do this and the description is too long to write here. Best is to search google for flashing field generator. I would try the trick using a single speed drill motor first as it is a safe method. You must lock the drill on and it cannot be a type with a throttling trigger. Plug into the 110 receptacle and with breaker on give the drill a spin with your hand. This is with the generator running. More drastic steps using a battery need to be done with generator stopped.
Nov 06, 2011 | Coleman Powermate Premium Plus 6250W...
I have a coleman vangard generator 7000 watt and it will not produce power any more,when it quit producing power it was running and then just up and stopped producing power but the motor was still running....
gen sets require a dc voltage to energize the field windings and there is a voltage regulator built in
That could be faulty
talk with your local genset repair shop to get ideas
May 27, 2017 | Coleman Electrical Supplies
We just bought a coleman powermate 5,000-6250 gen and it runs great but will not produce electricity. i hooked a 75 watt bulb up to each plug in and it would just barely come on the fade out. but would...
Your generator produces proper voltage and 60 cycles at 3600 rpm. Use meter to adjust voltage/engine rpm. If after adjusting rpm setting and gen. does not have proper power, remove cover to generator and examine brushes and commutator rings for wear and voltage regulator/rectifier for burned components swolen or leaking capacitor and replace parts as necessary. Parts are available www.jackssmallengine.com Good luck
Sep 09, 2010 | Coleman Powermate Powermate 5000W...
My coleman powermate 6250 generator just stopped producing electricity. It was running all day. Motor still runs just no juice.
check the reset-- if power to reset line, switch bad if no power -check feed out from generator if no out put then possible internal problem --winding or short
Mar 02, 2010 | Coleman Powermate Premium Plus 6250W...
I have a coleman powermate 6250-5000 running watts-generator. The generator starts and runs but does not produce current to outlets,the outlets are fine-they have continunity,I removrd the armature and...
You may have just lost residual magnetism in your rotor. Start genset then apply 12 vdc to 120 v outlet for less the 1 seconds. This will be enought to restore the residual magnetism to the rotor and the unit should be producing power now.
Nov 17, 2009 | Coleman Powermate Premium Plus 6250W...
I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Oct 07, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
601 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
