Question about SanDisk Sansa Clip MP3 Player
Sansa Clip stuck on "refreshing database"
I have a 2GB Sansa Clip bought about a year ago.
Recently when I uploaded new MP3s into it and after disconnecting it from the computer, it began the usual "refresh database" routine. This time however, when the loading bar reached very close to the end, it just froze.
-I tried waiting. Several hours later the battery was empty but right before turning off the display STILL showed "Refreshing database".
-When I plug it into the computer it behaves normally, it charges up the battery and lets me upload and erase songs. However when I plug it out the process starts again, and freezes again near the end.
-When the display is stuck on "refreshing database" I can turn the player off. However when I turn it on again it repeats the "refreshing database" routine and gets stuck at the end, again.
-I've managed to partially circumvent the problem by turning the player off and on again while its plugged into the computer. When I unplug it later I can play songs but the database isn't refreshed, it doesn't show songs I've added, and shows songs I've deleted (but of course can't play them).
HELP!
ThaMp3Doctor
  • 8596 Answers
SOURCE: Stuck on Refreshing Database
It needs a firmware upgrade, most likely. Read the following for every possible recovery method:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 07, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Freezes on refreshing database
-Tha Mp3 Doctor
Posted on Feb 15, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: "Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Posted on Mar 18, 2009
  • 13 Answers
SOURCE: Database not refreshing, Could not listen the new songs added
go into your menu go into veiw all songs then go to play all
Posted on May 06, 2009
YourZEN
  • 820 Answers
SOURCE: refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Posted on Sep 20, 2009
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
I reformatted my unit at my pc.. then it keeps saying refresh database... what can i do??
For the Sansa Clip, first try to RESET the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
If the player still freezes with the refresh database message, after a reset:
then update the firmware. Next link shows how to update the Sansa Clip:
http://kb.sandisk.com/app/answers/detail/a_id/300
In METHOD 1 is explained how to use the sansa updater, for Windows operating system.
METHOD 2 tells where to find the online sansa forum for updating manually.
Jun 27, 2010 | SanDisk Sansa Clip MP3 Player
The sansa clip got stuck on
try contacting sandisk or something and ask them
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Stuck on fresh database
Some songs or files with extension device can't read, so it takes so long/infinity to refresh. Plug the device to pc, format it.
Good luck
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 2GB stuck on refresh after charging
download the firmware update!
I had same prob- gone after update
here is link to update:
http://www.sansa.com/support/sansa_clip/faqs
good luck
Joe
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
My Sansa 1 gb clip is stuck on the refresh database screen, and the bar is stuck on a small amount of progress.
Rebooting the device usually helps with this.
Any time it's 'stuck', you can do a soft reset (reboot) by holding the power/hold button up in the 'on' position while pressing the center-round button for a few seconds.
If it defaults to off, it should restart normally by using the power-on switch.
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Where can i find the driver for sansa clip mp3 2gb? where i can find the driver for sansa clip mp3 2gb
Go to sandisk.com. Click on downloads. Select sansa clip from the product list, then your operating system. You can get the updated driver and user manual.
Dec 10, 2008 | SanDisk Sansa Clip MP3 Player
Sandisk player stuck in refresh loop
When you have many thousand files, it will happen rarely... You try formatting and then copy files back and try again. And also avoid unsupported files.
Sep 25, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
122 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
