Question about Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera
Canon IXUS 800is no image on LCD display
LCD is working in playback mode. When I try to take a picture the screen is black. If I then take the picture and play it back - it's black
  • 99 Answers
SOURCE: LCD does not display image in record mode
ssue: The LCD/Electronic Viewfinder will not display an image or the image is distorted.
1. Press display (DISP.) button to turn the display on 2. If all troubleshooting has failed, please have your PowerShot A520 serviced
Posted on Feb 08, 2008
SOURCE: canon powershot g3
a common problem is with the 'optical unit' shutter control part.
have to replace the 'optical unit'
Posted on Jan 31, 2008
SOURCE: no image in the LCD, its black
restore the factory settings
turn camera on, press the menu button for 5 seconds and the default setting comes up. select ok and it all goes back to normal. I think that the exposure was wrong, therefore not letting enough light so the screen always appeared black.
Posted on Jul 29, 2008
xscrewdriver
  • 246 Answers
SOURCE: My canon sx10 is LCD display will come on when in
Press DISP button repeatedly until you can display
Posted on Jul 13, 2009
  • 11967 Answers
SOURCE: Sd card won't upload video- 'unidentified image' is displayed
iPhoto is for still pictures. iMovie is for videos. Use a card reader to download your videos to a folder you create on your desktop. From there, you can import to iMovie or just play them using Quicktime.
Posted on Apr 26, 2010
Testimonial: "Spot on... problem sorted. It seems iphoto is happy to load short clips but longer vids are too much so quicktime was the solution. thanks :-)"
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Black lcd screen on Ixus 70 shows icons but will not take picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a Canon IXUS 960 IS. The screen shows no image when taking a photo yet shows menu information and works fine for playback. Is this a fault or have I accidently made a wrong setting somewhere. Any...
Try pressing "DISP." which is the small button on the bottom left under the thumb-wheel. That turns on or off the LCD in shooting mode. In Playback mode, it shows shooting information etc.
Apr 06, 2009 | Canon IXUS 960 IS Digital Camera
Canon DIGITAL IXUS V2
The problem is the iris is stuck.
The solution is:
1. Move the camera to TV mode(the wheel with AUTO,M,TV,...)
2. Set the exposure time to 15 seconds(15")
3. Take a picture.
4. After 7 seconds remove the batteries and put them back on.
5. Repeat the procedure until it works.
Jan 30, 2009 | Canon IXUS V2 Digital Camera
SD300 LCD Display Shows Same Image
Sounds like it needs service. Call Canon tech support.
May 28, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Black display
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 25, 2008 | Canon PowerShot A80 Digital Camera
Blank LCD Screen when in shoot mode
Mar 23, 2008 | Canon PowerShot SD100 / IXUS II Digital...
Canon powershot S400 LCD screen image jumbled
This sounds like it might be a defective CCD imager. This will get worse with time, and the pictures may be jumbled next. Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Jan 21, 2008 | Canon PowerShot A75 Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera Logo
525 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
