Question about Euro-Pro Dressmaker 998B
Bobbin filler spring broken - Euro-Pro Dressmaker 998B
Bobbin case spring
These guys should have the part.
Apr 01, 2014 | Montgomery Ward Sewing Machines
The black plastic piece the bobbin fit in is broken.
You may have a timing problem or bent needle. You will need to replace the bobbin basket if it is damaged.
Jan 28, 2014 | Singer 7466 Mechanical Sewing Machine
Upper thread is not catching bobbin thread
Carmen, seem that you have carried out the necessary rectification, but could it be your rotary hook tip blunt/broken, if not most probably it needs needle/hook timing adjustment. And this will require your sewing machine technician to do it.
Jul 24, 2013 | Sewing Machines
Bobbin icon problem
you might think about having the machine checked to see if there is something wrong with the computer part of the machine
May 23, 2012 | Bernina Sewing Machines
I tried to fill the bobbin with thread and it does not turn. I have used my machine for years and this has never happened before. I tried several bobbins and none worked. Hope you can...
Hi. There is usually a small wire spring sticking out through a slot in the bobbin winding stem which holds the bobbin to the stem. If the stem is rotating but the bobbin is not, chances are this spring may have gotten pushed down too far into the hollow bobbin winding stem or maybe broken or lost.
Feb 25, 2011 | White Sewing 2037 Mechanical Sewing...
No tension on bobbin thread
You might remove the bobbin assembly looking for a broken tension spring (maybe a piece of it lying in the bottom the bobbin case.
Jul 19, 2009 | Husqvarna Freesia 425
Pfaff 2040 Tiptronics bobbin case rotating out of position
Sounds like you need to put a drop of clear sewing machine oil in the raceway of the hook. Then sew on some scrap material to soak up the excess oil.
Mar 10, 2009 | PfaFF Tiptronic 2040
Sewing machine husqvarna 3610 bobbin case spring has broken and the bobbin will not stay in the machine. How do I repair the spring?
You probably will need to replace the bobbin case. It is probably only available from Husqvarna Viking. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jul 21, 2008 | Husqvarna Viking 1
Needle doesnt hook bobbin thread while sewing
Our machine had the same problem, there was a piece of broken thread stuck in the upper tension spring keeping the tension spring open. removing the broken thread in the upper tension solved the problem for us
Feb 20, 2007 | Simplicity SE3 Computerized Sewing Machine
Euro-Pro Dressmaker 998B Logo
21 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
