Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon IP4000 won't grab the paper
Just all of a sudden the printer stopped grabbing the paper and can't deliver it into the printer, every once in a while I would get a "load paper" message. I don't know how to take it apart to see if it is a small motor problem or a roller problem or what. I really like this printer or I wouldn't mess with it ......... Dwight
  • 432 Answers
If you take the paper out and the paper tray if possible and get some wd40 and a cotton pad or some pad to use to wipe the wd40 onto the rollers ( only a small amount as you dont want to drench the rollers with wd40 ) and let it dry out for a few mins and then try it again.
If its the rollers then that should help
Posted on Jun 04, 2009
Why does my printer grab several pages of paper at once instead of one?
The printer when it was cleaned for paper jam might have damaged paper rollers which picks the paper as the gap is increased due to paper pull.You can replace rollers then problem will be solved .
Jul 20, 2014 | Canon PIXMA MP160 All-In-One InkJet...
Paper feeder grabs several pieces of paper at once
The spot in which the paper is fed into could have a fence/blocker. Use wood or a little hunk of aluminum to only allow 1 sheet. You could get fandy and use a rod that could also be mounted on the font.Be crea8tive and good luck.
Jul 21, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Will not grab paper. says out of paper when its not
You can try cleaning the rubber wheels with alcohol. Sometimes they become covered in dust and won't grab the paper.
Apr 08, 2012 | HP OfficeJet 7410 All-In-One InkJet...
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Hi - My daughters Canon MP 210 printer stopped pulling paper into the printer. I did not observe any spinning of the paper grab wheel therefore I'm wondering if a drive belt broke or something else is not...
hello there
you need to check the gear that trigger the paper to pull from the tray, if the gear is making a sound when you print then totally you need to open the gear coz it might be disconnected.
thanks
Dec 23, 2010 | Canon PIXMA MP210 InkJet Printer
Printer does not grab paper any more
SOMETHING MOST LIKELY FELL IN THE BACK PAPER PATH SOMETIMES HARD TO SEE
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Not grabbing paper
Try cleaning the rollers again and fan the paper. When you clean the rollers, use alcohol and a lint free cloth. Don't put too many sheets in the feed tray.
Feb 04, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Printer problem
Sometimesa feed roller can become smooth and it no longer grabs the paper.
If you ahve some emery cloth try to rub it gently on all rollers to roughen them up a bit.
Jul 05, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
206 people viewed this question
old marine
old marine
