Question about RIM BlackBerry Curve 8310 Smartphone
I put a plastic screen protector on my blackberry 8310 and when trying to remove the screen protector because it was twisted,spots like water appeared between the lcd screen and the plastic cover of the phone. Someone can help me?
    Problem Solver:
  • 12 Answers
When you put the plastic screen on make sure that the plastic and the screen on the phone are absolutely clean. If there is any dirt or debris on either the plastic screen will not sit directly on the phone and bubble up where there is residue.
Posted on Jun 04, 2009
What is the code to unlock the blackberry 8310 curve
Do you need to unlock your Blackberry Curve 8310 from network lock?Blackberry has 10 unlocking tries..So you have 4 remaining unlocking tries.You can get the unlock code from the site
Classicunlocking.com for Blackberry Curve 8310 and unlock it easily using the unlocking instructions below...
Blackberry Curve 8310 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Blackberry Curve 8310 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
Oct 26, 2012 | RIM BlackBerry 8700c Cellular Phone
The track boll and keyad of my blackberry set 8320is not working i can juat see the screen when wither i fix it on charger or when i remove it can u please tell me some economic solution........?
http://www.truesupplier.com/wholesale-oem-full-blackberry-curve-8300-8310-8320-black-covers-c-890-p-1-pr-19189.html
http://www.truesupplier.com/_search.php?page=1&q=blackberry+8300+trackball
I've purchased items from Truesupplier.com before and they provide excellent service.
You'll need to purchase another keyboard/housing and a trackball for your phone.
You'll need a T6/T4 screwdriver. This can be bought from Lowe's/Home Depot.
There are several videos on youtube that show the replacement of your housing.
This is the easiest way to fix your keyboard and trackball.
May 16, 2011 | Valor Fits Blackberry Curve 8300 8310 8320...
BB curve 8310 keyboard is not working properly
yea i have the same problem A,F,J,K,"DEL", "ENTER","ALT",X,B,V,$ these keys are not working. Last night they sudenly started working but then stopped 2 minutes later, my Blackberry wasnt dropped neither did it have any water damage. most is i have the ball removed as i await a replacement ball
Apr 06, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry 8310 curve wont turn on!
take out the battery and put it back in after about a minute
Dec 29, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
When i Put my battery in my blackberry 8310 the screen flashes blank white and also the red Led keeps flashing.
Remove the battery again and leave it out for 30 mins. This should be enough to reset the BlackBerry.
If same problem occurs, then contact the manufacturer for repair. It could be the chip, loose connection or cold soldered or corrupted program.
Have a great day!
Oct 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry 8700g screen lens replacement directions needed
Hi.....don't know if you have already resolved this problem, but if not, you can view this video on you tube which shows you exactly how to do it. This doesn't say 8330 but still applies same as the others.  BlackBerry 8300 8310 8320 lens replacement proceedure
Apr 19, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My computer will not format my memory card for my blackberry
Put SD card into adapter format on PC Fat32,
put in blackberry should work fine.
Apr 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8310
Try taking the battery out for a minute. Then put it back in...it should reload on it's own.
Mar 31, 2009 | RIM BlackBerry Curve 8310 Smartphone
Trackball issue
The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! Like you should be during the whole process as all parts have very small plastic nipple which can break very easy. When the silver plastic ring is removed you will see the inner trackball component which can be removed completely. Before doing this you should carefully remove the silver metal ring that holds the trackball component in its position. The trackball component itself can also be carved. For every direction the ball can roll to you’ll find a sensor wheel. Those wheels are mostly carrying some gunk you should clean them from. Once this is done put everything back together to the place the pieces came from and secure the trackball with the silver plastic ring you removed in the first step. Your BlackBerry’s trackball should be back working now.
YOU NEED TO CLEAN JUST SENSOR WHEELS NOT BALLS ITSELF.
BlackBerry Pearl Trackball Cleaning Screen Shot
Jun 26, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
130 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
