Question about Dryers
Dryer won't heat---seems to work fine, but no heat. Removed the back panel, but not sure what I'm looking for...HELP!!
  • 142 Answers
From the way you describe it, sounds like the heating element is gone. It is located under the silver tube under the back cover.
Check to make sure there are no breaks in the element.
The element looks like a big long spring..
Posted on Jun 04, 2009
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Bosch nexxt 500 series electric dryer will not heat up, it just blows cold air. I have removed the back panel and pressed the reset button-nothing changed it still won't heat. The dryer had been in...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Bosch Dryers
Just moved the dryer to new home after having it in storage for 18 months. Plugged it in and it doesn't do anything. Tested house circuit and it is fine. Tested the dryer at the cord connection and it is...
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
as seen on heatmans blog
Apr 29, 2011 | LG DLEX7177 Dryer
I have a Maytag Neptune gas dryer (MDG5500). The dryer overall seems to be working fine, but there is NO heat (Just a very recent problem). I have removed the front access panel but I am unsure exactly...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 06, 2010 | Dryers
Heating element went bad in whirlpool dryer replaced it and worked fine for about 10 minutes then it stopped heating. took element back off and it looks fine help me plz
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 11, 2010 | Kenmore 84152 Electric Dryer
Our Neptune gas dryer seems to work fine but suddenly produces no heat. The vent is clear and the gas line attached and open.
Look at the glow ignitor. If it is broken then it needs to be replaced. About 20 dollars, and a 5/16 wrench will fix this issue, just make sure that you unplug the dryer before you start touching the electrical. This piece is located in the bottom of the dryer behind the back panel.
May 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Can't remove back of Kenmore 66901
believe that model has lower front panel remove it ..clips each side top edge press them down pull panel off ..element ,fuses thermostat behind it
Nov 18, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
