Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Weedeater won't take fuel
My Poulan Weedeater keeps stalling when I push the throttle. it idles fine at "RUN" but will not take any throttle it just sounds like it is flooding and nearly dies unless i release the throttle and then it idles fine again. Cna some one help?
  • 1,040 Answers
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Posted on Jun 05, 2009
  • Jim Parker
    Jim Parker Jun 07, 2009
    Thanks for the rating. If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to "Category: Tools-Building & Power-Hand Tools" at FixYa.com
    Thanks Again,
    Jim
Poulan HD145H42H stalls after a little while of mowing. When I re-start it will start at idle throttle then stalls again when I throttle up or engage the blades. Any ideas?
Hi John:
Have you checked the basic maintenance items?
- Air filter
- Fuel filter
- Fresh fuel
- Oil level
- Spark plug condition
- Clogged underside of cutting deck
May 28, 2015 | Poulan Garden
Stihl weedeater stalls when I compress throttle trigger
dump the fuel --clean air filter-change spark plug-- use new fuel synthetic 2 cycle oil--93 octane
Oct 11, 2014 | Stihl Garden
Excaliber ght180 cuts out
Rebuild carburetor or find part number for carburetor and go online some carbs. Are cheaper to buy than rebuild.
Sep 13, 2017 | Garden
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
I have a Poulan WeedEater. It had trouble
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan pro weedeater will start fine run untill you pick it up then dies
poulan has a bad habit of the fuel breaking inside the tank if it breaks before the fuel filter that makes the fuel line shorter
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Weed eater GTI 17 won't run on high speed
A couple of things may work...
Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
May 19, 2009 | Poulan Genuine Weedeater Part # 36006-128
Weedeater fuel line oopsy
I fed the fuel line up through the bottom, attached the filter and pulled it backk towards the hole in the bottom of the tank. I then used a brake adjustment tool to first push the filter back in place (with the line attached) then hold by pressing down on the top of the filter while I hooked up the little plastic clamp.
All that seems to work fine but the weed eater won't idle AT ALL.
May 02, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
I have a poulan pro 38cc 16"chainsaw about 5 yrs. old. It ran fine until I let it sit too long and when I went to use it,discovered the fuel lines had disentegrated. Replaced the lines,drained the fuel and...
SOUNDS LIKE YOU FOLLOWED ALL THE CORRECT PROCEDURES. TRY TO GOOGLE SEARCH YOUR POULAN PRO MODEL #, I'VE HAD ALOT OF LUCK GETTING MANUALS AND DIAGRAMS FROM THERE. GOOD LUCK!!!
Jan 24, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
1,131 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
