Question about Kitchen Ranges
I get a message FSE0 about 15 minutes into my selfcleaning mode of my Super Capacity 465 Whirlpool electric range. What does this mean?
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: problem with electric range
Most likely the switch has welded closed
Posted on Sep 28, 2007
SOURCE: whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
  • 58 Answers
SOURCE: Whirlpool Super Capacity 465 Electric Range not heating properly.
The first thing you will need to do is to verify that you have 230 volts at the outlet. Chances are pretty good that the unit popped one of the double pole breakers. Check the breaker and reset it if you find that you only have 120 volts at the outlet. If after finding that you have only 120 volts and you've reset the breaker then the problem would lie with the breaker needing replacement. If however you have full 230 volts available at the outlet then additional troubleshooting would be needed. Hope this helps... Bill
Posted on May 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: Super capacity 465 Whirlpool range . E1 F5 code
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.ER%^
Posted on Oct 01, 2010
I have a Super Capacity 465 range and I am getting an error message when I turn my oven on and it begins to warm up. The error message is E2 -F1-. Can you tell me what this is?
Hi jwheeler5863,
The fault code means UL A/D error. To get rid of this error please follow the steps below.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board also called ERC or clock.
Hope it helps.
Thank you for using FixYa.
Sep 14, 2011 | Whirlpool Kitchen Ranges
Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
Jan 20, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
I have a whirlpool super capacity 465 electric range. i get error codes that beep and flash e1 and f1?
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Nov 25, 2009 | Whirlpool GS460 Gas Kitchen Range
I have a Whirlpool Super Capacity 465 range and received the error messages E4 F3. What does this mean?
if you call me @ 570 263 0077 i will check my fault code list and let you know what those codes meam thanks JOHN
Nov 08, 2009 | Whirlpool GR460 Electric Kitchen Range
Heating elements
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Feb 01, 2009 | Whirlpool GR460 Electric Kitchen Range
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kitchen Ranges Logo
253 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
