Question about Sta Rite Dyna Glas Pump 1 Hp Ne857
My pump just humms willnot pump water
  • 700 Answers
Im talking about general troubleshooting here. Usually with this size of motor 1Hp. Check if it have a capacitor, commonly if this humms the capacitor is faulty. It is a capacitor start motor. Another fault could be stuck up. Or one of the winding has a short. Hope it helps
Posted on Jun 04, 2009
Water not pumping out of machine-zanusi aquarius wf000
1. Check that the water tube is properly fixed
2. The tap is on
3. The program is on
If you hear a humm sound without water means that the valve is open but is closed before that.
If no humm is heard then the valve could be broken.
Apr 02, 2014 | Hotpoint Aquarius WF000 Front Load Washer
1 hp water well pump hums but willnot start shaft to well is free
You may have an air lock/bubble. Try priming the pump with water before you switch on the pump.
Feb 29, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
DEHUMIDIFIER TURNS ON PUT HUMMES AND TOP GETS HOT--SEEMS LIKE COMPRESSER DOESN'T KICK IN- ARE THE TWO CIRCUIT BOARD PARTS TO BE CONNECTED INSIDE ???? MINE WEREN'T WHEN I TOOK OFF FRONT CASE
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 06, 2011 | Dehumidifiers
My pump will not **** or blow water it just humms is there anything i can do
check might be air bound and have to bled air out of pump-or impeller damaged or jammed with debris usually if jammed will pop breaker
Jun 10, 2010 | Intex 1000 Gallon Swimming Pool Filter...
Water not coming out of machine
If water is in machine and not pumping out there could be a blockage in the outlet pipe or pump. If you can not hear the humm of the pump then there may be a pump fault. Possibly just a blokage in the outlet pipe though.
Feb 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My heat willnot come on all i here is humm in the unit under the house and nothing inthe outside unit it is a "Googman-ARUF02400A1"
Ok, If you don't have a heat pump, you should not be hearing anything from the outside unit. I assume you have electric heat. I feel strongly that you have a bad fan motor capacitor. This is what sends a jolt of power to start the fan motor. Good luck and have a great day.
Oct 18, 2009 | Goodman Heating & Cooling
Cold weather does not start
Need to listen for fuel pump humm for proper operation. Shoud humm for about 3 seconds with key turned in the on position. Humm will sound from gas tank where the pump is located. If it does not humm. possible Faulty Fuel pump relay or pump. It will need ferther diagnosis.
Jan 09, 2009 | 1998 Chevrolet Cavalier
Pump keeps running & willnot let water in
i assume you mean drain pump.
machine probably has water in base. if you can, take bottom kick plate off and mop out the water - disconnect from mains when you do this. alternatively, tilt machine back at 45deg and water will run out.
if fault reoccurs, then you have a leak
Jul 14, 2008 | Dishwashers
Sta Rite Dyna Glas Pump 1 Hp Ne857 Logo
310 people viewed this question
Top Sta Rite Garden Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
