Question about ViewSonic VA721 17" LCD Monitor
IBM LCD computer monitor is dim
I bought a used 15" IBM LCD monitor that is not very bright even when the controls are turn up to the max. I'm pretty handy with electronic repair. Is this a somewhat inexpensive repair like changing some bulbs? (not an expensive screen as the picture and colors are fine)
    Genius:
  • 1,601 Answers
Your backlight may be going bad, or the small controller board may be going bad also. You will have to contact ViewSonic for prices. It is not that difficult to change them out.
Posted on Nov 29, 2007
SOURCE:
Dim problem
Here is the link to the monitor's User Guide. Page 2-3 explains how to use the On Screen Display (OSD)
Dec 09, 2013 | IBM ThinkVision L151 15" LCD Monitor
Dim display problem
Have you tried adjusting the LCD's bright and contrast using the buttons on the monitor. Instructions can be found on page 12 of this manual:
https://computinghardware.web.cern.ch/ComputingHardware/doc/Samsung/SyncMaster740B/SyncMaster740B-940T-E.pdf
If the lcd monitor is dim even upon booting up, then the backlights of the lcd itself is starting to fail and it needs to be replaced.
Please let me know if you need further assistance. Thank you for using FixYa. Merry Christmas!
Dec 25, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Lcd is very dim. after changing res a glow in the lower right corner starts then back to darkness. It works fine with my vga monitor.
Hi, display DIM cause by LCD or inverter Board (brightness controller). Might costly. Up to you either want to change it or not.
And using external monitor is best solution, I think so. =)
May 08, 2010 | IBM ThinkPad R51 Notebook
MY ACER MONITOR IS DIM , HOW DO I BRIGHTEN IT UP?
Push the button on the front that says menu. Within that menu you will find the brightness control. Use the other buttons to move through the different menu items until you get to Brightness. Once there push the menu button again and then adjust the brightness with the other buttons.
Nov 27, 2009 | Acer AL1916W 19" LCD Monitor
Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Sep 28, 2009 | iiyama ProLite E434S 17" LCD Monitor
Monitor problem
Hi ,
you set the Brightness manually or otherwise you will repair the monitor.
Thanks
Aug 15, 2009 | IBM E54 15" CRT Monitor
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Monitor too dark....
Usually every laptop has the option of adjusting the screen brightness as you would want the screen to be pretty dim when running on battery to conserve battery life.
First thing to check would be just that.
Dec 11, 2007 | Apple Colorsync 850 Monitor
Too bright
I just bought an Acer 19 inch this morning and I am assuming you have the same controls on the bottom of monitor. On mine I push the menu button twice....the left arrow once to select the brightness slider.....push the menu button again to turn slider red and active...then use your left or right arrows to adjust brightness...afterwards you use the menu to get you back to the exit button and that's it....I hope Don
Dec 07, 2007 | Acer AL2016W 20" LCD Monitor
Have lost ability to control brightness.
lost,
wow a CRT that even glows at all , and you wonder why its dem
the electron gun cathodes get weaker every day of its life.
all CRTs do that, not one or even TVs using CRT
the red gun always goes dim first so we crank it up in the OSD.
if it fails on all PCs, the monitor is bad, a 5 min test. and bingo
then if the monitor is known bad then what.
the OSD screen ever seen that, and the front panel key marked MENU/?
go there and play with brightness, and even the electron gun tuning, the page for that is RGB, Red Green blue.
adjust them so white looks OK.
but if all are dim, that is normal for old CRT,
we only get like 3 folks a year stuck in 1990s... or older.
the labor to fix it is 3 times a new LCD LED display.
land fill time. like the other billion made, and scrapped
Nov 20, 2017 | Compaq Presario 1510 (White) 15 in.CRT...
ViewSonic VA721 17" LCD Monitor Logo
90 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
