Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
The spring is broke on the starter on my Poulan PPB200E trimmer
The pull cord will not retract. I believe the spring is broke. what is the part numberto order a spring? how do I replace it?
  • mark groves
    mark groves May 11, 2010
    what model and serial number is it
SOURCE: recoil spring broken
you need to supply the brand and model of the blower so i can look it up
Posted on Feb 15, 2009
  • 246 Answers
SOURCE: How do you change pull rope on Poulan pole trimmer
Hello theframptons:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog Poulan/Weed Eater.
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 376 Answers
SOURCE: starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
Posted on May 26, 2009
bobbyburns
SOURCE: Reattaching the recoil spring to the rope pulley
i have the same probelm
Posted on Jul 08, 2009
  • 76 Answers
SOURCE: replace string on trimmer
Hi
check in you tube .
The video is talking about trimmer strings in general , but my experience is that all trimmers are more or less the same.
hope it helps
http://www.youtube.com/watch?v=WFu66Q6J62Q
Posted on Jul 16, 2009
How do I replace the pull cord to my Poulan 446T PRO. It's a combination of a pole chain saw (8 inch) and a trimmer.
You will take the recoil assembly off the saw. You shoud see where the knot broke off the cord in the pulley. Put the cord through the case and the small hole in the pulley and tie a new knot. Count the number of turns it takes to take up the rope. There should be a small notch in the edge of the pulley you place the rope in to wind up the spring and not take up the rope.Add one or two turns more than you counted so the rope is coiled up snug then pull out the rope from the notch and let the spring retract it.
Aug 02, 2013 | Garden
Pull cord won't retract
Hi Susan. It sounds like the spring has either snapped or become un attached. It's going to be a two person job to re do it. It may be worth while going to a scrap metal merchant and getting the recoil starter of an old mower.
Jul 26, 2013 | Poulan Garden
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
The starter string does not retract after being pulled on my Echo weed trimmer
spring probably broke for recoil,will have to pull the 4 screws holding it on and and pull recoil off
you might get lucky as you loosen the bolts it might retract, if it does it is dirty inside and possible nylon guides wore causing it to bind. otherwise spring prob broke inside
Apr 03, 2011 | Echo Garden
How do i replace a pull cord on poulan 031 pro
This is a tricky job, you have to extract the assembly, remove all old cord, wind the spring and pulley fully, and back off a turn or so, lock the pulley, install the new cord, release the pulley and it will wind in the new cord. reinstall starter assembly.
Try to resist handling the spring, they are messy, uncooperative and hard to reinstall.
Oct 05, 2010 | Poulan Garden
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
Cord won't retract
The spring is either broken or the catch on the end of it isn't seated, this is a coil spring inside the hub, probaly has to be rewound to gain the tension back
Aug 22, 2009 | Garden
Pull cord stays out, won't retract. I took apart
the end of the spring may be broking you can fix it by taking it out and heat it with a small fire until it is red hot and bend it
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Jul 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
461 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
