Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a Husqvarna YTH 2348 the deck anti sway bar came looses fell of frame and bent, I removed rod strightened and need to kown how to put rod back in proper location on the frame and deck bracket
Once you've straightened it - you've finished the hard part. Now take the end without the pin and stick it into the hole located on the transmission frame (the metal piece that the transmission sits on.) It is directly under the seat. The hole is on the front side of the tranny frame. Once you have it all the way in, take the pin end and put it through the mower deck brace (right side.) There is a hole there also for this end. If it doesn't go through enough to get the washer and pin through, push the mower deck towards the anti-sway bar. It should give a lot since the anti-sway bar is off. Once you fasten it, your'e done!
I only know this because it just happened to me today. I have the same mower as you, so I thought I would share.
Posted on Jul 04, 2009
Hit a large root today now the bar is bent. I need to replace it or bend it back? Not sure if I can get it bent back straight or not. Those darn shallow roots from the walnut tree.
Posted on May 03, 2014
    Problem Solver:
  • 10 Answers
I just had the same thing happen on my 54 inch model. I mowed without the bar in place and it really left some gouges in the yard. I've put it back on now and it mows much better. I wonder if this is a common problem. I also don't know what caused the bar to come off in the first place as I don't see any dents or dings in the mower deck.
Posted on Oct 12, 2009
Blade wont engage on a Husqvarna yth 2348
With the engine off, Check the tension on the deck belt. If tension is tight then disengage the blades and check the blade pulleys and see if the move freely.
Oct 08, 2014 | Garden
How do you Assemble the anti-sway rod on a Husqvarna mowing deck?
The anti-sway bar fits into the frame. Then the sway bar then fits into the deck and connects with a washer and clip.
Sep 04, 2014 | Husqvarna Fast Tractor YTH24K48 48" 24HP...
A steel rod runs from one side of deck to the other side of deck. It broke off one side and is being held on the other side by a pin. The broken side digs into the ground when in reverse and is bent. Do...
Go to Partstree.com.
Search for Husqvarna, use your model number.
Have your serial number ready.
The part is called "anti-sway rod" and costs about $14.
You may need a clip or end connector, too.
Gary
Jun 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
What battery size and voltage do I need for a YTH 2348
My name is Dane and I am going to try to help you solve your problem.
Your battery should be a 12VDC 330 AMP.
I hope I
Dec 04, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Belt replacement on a husqvarna yth 2348 mower
do you need to know the belt configuration for this mower ive attached a user manual that shows the configuration and all adjustments on the deck and belt...
http://72.3.225.179/manuals/YTH2348-ow-e-96045000502-420798_r0.pdf
Hope this helps
Kind Regards
Brad
Dec 28, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
2,526 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
