Question about Coleman Powermate Powermate 5000W Generator
STARTS FINE (TECUMSEH H1OO ENGINE) BUT RUNS RICH. NO ADJUSTMENT AVAILABLE ON CARB. ANY SUGGESTIONS?
  • 32 Answers
First off, is this an LPG, Nat Gas, or Gasoline powered unit? If you are sure that it is running too rich and you have no adjustment; the easiest way to reduce the volume of liquid going to the carb would be to put a regulating valve in the line somewhere. you could use a gate valve or even a ball valve if you had to.
Posted on Jun 13, 2009
5 hp tecumseh no power
you need to remove carb for cleaning... if it has an adjustment on the bottom of carb try turning it SLOWLY in and out... also possibly a screw on the side under a black cap... might try it as well engine model number would help here
Dec 11, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Our HMSK 80-110 electric start snowblower starts up right away, but the idling is very rough. It runs very smoothly when it is engaged in snow throwing.
The Tecumseh snow motors are notorious for idling rough. Especially the last few years of production. Most service techs just say "live with it" But there are a couple of things you can do to help.
It is not a carb adjustment issue. It's usually a fuel, clean carb issue.
First, use a premium grade fuel without ethanol and a fuel stabilizer. This will give you the best fuel mix.
Second, Remove the carburetor shield and clean the inside and outside of the carb with carb cleaner. Even though you can't see the carb usually, they do get varnish build up and cleaning it will help some.
Third, Put the recommended amount of fuel system cleaner in the gas. I use Sea Foam brand. Over a tank full or two you will notice a difference in how the engine idles.
Fourth, Use a high quality spark plug and use a new one every year. Make sure the gap is correct.
Good Luck! Feel free to as any other questions you may have. Don't forget to rate this answer!
Jan 14, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Engine starts fine but lacks power until it warms up for 2 to 5 minutes. Carb is ok, replaced head gasket. Just started doing this
If it starts at completely cold to fine tune the high jet adjustment.first off the high speed jet should be initially set at 1 1/2 turns out from lightly bottomed all the way in. next when you do your prestart routine,choke all the way on,primer pumped two times,throttle set at the high speed position,ignition key on,fuel line turned on.(this is my prestartup for my 8hp tecumseh)yours may be slightly different.use whatever starts your machine the easiest! once my machine starts up i can almost immediately turn the choke completely off. i can do that because the high speed jet is opened enough or rich enough for the engine to run.if you adjust the high speed in it will lean the motor out(you found that to be true!) to where it will miss and backfire and eventually quit. start at 1 1/2 turns out and start the engine,once the engine starts if you take the choke off right away use what it does as a guide to high speed adjustment. if the engine quits turn the screw out 1/4 turn and so on.use the very first cold startup as the test for high speed mixture adjustment. at completely cold startup you have the jet adjusted correctly when the engine will sustain itself when you completely take the choke off very shortly after startup. let the amount of choke you need at cold start to keep the engine running be your guide.too lean and the engine will not stay running without the choke at all,too rich and the engine will not pull under extreme loads and will show signs of black soot out the exhaust. you want the jet adjusted so within 5 seconds of cold start the engine will stay running with no choke at all. find that needle setting ( don't ad any more!! ) and you'll be good to go.keep in mind the above is not optimum and is a little rich but you will like the way it starts,stays running,and overall performs as adjusted above.
Oct 03, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I have a Craftsman Yard Man 6.5hp push mower with a Briggs & Stratton engine. The engine starts and runs fine for about 30 seconds or so then slowly dies out. It turns over slower and slower until it...
Have you checked the choke that it is off after you get the engine started,the black smoke is definitely from the choke, if you take the carb off and check that the needle closes when it should,as one can easily do an adjustment by bending the float/tab,rgds
Sep 25, 2010 | Briggs & Stratton Garden
8hp Tecumseh engine how to adjust carb. when I put throttle on high it sputters drop the throttle back down its okay?
These symptoms indicate a rich mixture. Assuming the carb is the original (and therefore correct) one, and that it has an adjustable main jet, turn in the main jet adjustment screw on the bottom of the float bowl until the engine runs smooth.
If there is no adjustment on the float bowl, the carb will have to be removed and properly cleaned (ultrasonic cleaner recommended).
Oct 01, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I need to know how to adjust the carbureator on an tecumseh lawn mower model number 143.954500
If it has a float type carb, open it 1.5 turns. If it has a diaphram open it one turn. If it has a Walbro carb, there is no adjustment. Once you get the engine started you may adjust the carb to fine tune. Open until it begins to lose RPM's then close until it starts to lose RPM's. Return to a point between the two. Good luck...Lee
Sep 05, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh HM80 engine, new carb, won't run
Not the solid state ignition. If this were the problem the engine wouldn't start at all. There is some adjustment needed to the carb but without more info, I'm not sure what.
Jun 17, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh HM80 on coleman generator. won"t stabilize, backfires. new plug, fresh gas 'carb cleaned. starts first time'new air filter. any suggestions?
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Mar 01, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Coleman Powermate Powermate 5000W Generator Logo
325 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
