Datacard in the laptops slot
I put my datacard in the laptops slot but since the size of the slot is a bit large and datacard being small,it got stuck in the slot and im not able to get it out.
im in delhi,india and unable to find any information where i can get this rectified.plz help me.
thanks
I put Hwai v data card, i am unable to put in the, i want to know which is the right model of v data card for the HP 6720s model laptop
rvs ramarao
hyderabad
Posted on Apr 27, 2008
  • 117 Answers
What model datacard
Posted on Oct 30, 2007
LENOVO SD CARD DUMMY UPSIDEDOWN
This is late but I have an answer. The same thing happened to me. All I had to do was poke a small needle (a paperclip works too) into the right side of the SD Card slot and wiggle it around a bit. It'll be out in at the most 20 seconds.
Mar 17, 2013 | Lenovo Computers & Internet
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
Dvd is stuck in my ACER laptop how can I get it out
The Acer 5610 has an emergency eject hole to the right of the eject button on the right side of the computer. Find a paperclip and unfold it (or small allan wrench), push the end of the paper clip into the hole until you feel pressure. Press firmly and the optical disc tray should come slightly out of the machine. Grab and pull the tray out (gently). This should work even without power to the drive on any machine tray optical drive, if the tray mechanism is undamaged.
For a slot-loading optical drive, it's a bit trickier. You can try sliding another object into the slot and using it to pry or lift the stuck disc. The safest option is to use another optical disc or credit card sized item and double-sided sticky tape. Put a piece of the tape on the item and then remove the paper from the other side of the sticky tape. Slide the item into the drive with the sticky tape towards the stuck disc (down for most computers). Once far enough into the drive, lower your item and press the tape firmly onto the stuck disc. Lift up and try to pull the stuck disc up and out of the drive.
I hope this helps.
Oct 26, 2011 | Acer Aspire 5610 Notebook
Bathroom cabinet pull knob is stuck. Slot in screw is stripped out. Have put all new knobs on cabinets and drawers, this is the ONLY one that can't gt off !
Hello, annemoss, W/D here.
There is a product that is sold for stripped out screw heads. It has a grit in it, and you place a drop of it on the screwdriver before you put it into the stripped slot. The grit fills the strripped void and allows the screwdriver to get a good bite. The brand I have used is called "Screw Doctor", but there are others. The large "box" hardwares will have this type product, as will Sears.
Another alternative is to drill the screw head through to the shaft of the screw from the back side. Use your old screws that you have already taken out to determine the proper drill bit size. The aim with this method is to remove the screw without making the screw hole too much larger.
Best regards, --W/D--
Mar 19, 2011 | Home
I have a very litlle cd im afraid it will get stuck in the big insert. what should i do?
trust me it wont. cd drives have two sections one for small cds and one for big. make sure it's dead centre and you will be fine
Jan 16, 2011 | Computers & Internet
Does the Datacard SP35 work with photoshop? I cannot get mine to print from PS.
Yes, install the latest driver from Datacard.com and check your sizing and layout are compatible with card size. If fails save your img as a jpg and use the datacard softwarte
Aug 01, 2010 | Datacard SP35 Printer
To small emails
open internet explorer click view tab under view tab click text size....and you can choose from small, medium, or large...hope itll help..
Oct 02, 2009 | Computers & Internet
I cant find driver for windows xp 64 bit. the driver that are in datacard page not functioning in xp 64 bit
Try this link:
http://support.securitworld.com/pub/Drivers/ID_Card_Printers/Datacard-ID_Card_Printer_Drivers/
Apr 22, 2009 | Datacard SP55 Printer
Sd card stuck in memory reader of toshiba laptop
I had the same problem, read some of the proposed solutions and came up with one that worked for me! Here it is: (1) cut a piece of duct tape that is about half the width of the slot and a couple of inches long (2) use a small flat head screwdriver and depress the card down, so that a small gap is created above the card (3) take a second small flat head screwdriver and force the tape into the gap above the card - adhesive side towards card (4) continue to work the tape into the gap so that it covers as much of the card as possible (5) remove the screwdrivers and gently pull on the tape until the card is removed!
Apr 01, 2008 | Computers & Internet
Im trying to download viedo from my camcorder to my lap top and its says i need to install a certain software
a firewire cable will probably work better than a usb connection ( assuming your laptop has a firewire connector ) for video editing ;
Jul 31, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Computers & Internet Logo
83 people viewed this question
Alun Cox
David Payne
David Payne
